First post, by treeman
I was going through my parts box and looked closely on a old broken doner video card and it hit me to have a look at the bios, its a eprom by size and quick specs it seems to be a compatible replacement for a 486 512 bios, I have a board with suspected corrupt bios and never had a eprom to test with. anyway the old eeprom (486 bios) is
m27c512-15xfi
the eprom I pulled from the video card is
ht27c512-70
can I flash the bios for the 486 and use the ht27c512 instead of the m27c512?
my research from google says yes, but second option is very appreciated
Reply 2 of 7, by treeman
ahhok damn, thanx
Reply 3 of 7, by zyga64
Search for SST27SF512 on ebay. I can see pair for $2.2 including shipping. These are electrically erasable and programmable parts.
I've bought and successfully programmed SST27SF256 for my S3 Virge (VBE 2.0 compatible BIOS).
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-2@400 /64M /MGA-2064W+3dfx /ES1370
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 4 of 7, by treeman
thanks for the info yeah I think ill get a few 😀
Reply 5 of 7, by matze79
keropi wrote:
The HT27C512 is a OTP device which stands for "One Time Programmable" so you cannot erase it and write other data to it.
Hehe delete it with X-Rays 😁 and oven
Reply 6 of 7, by zyga64
I forgot to ask. Do you have access to eprom/flash programmer ? Check if this eeprom is on the list of supported devices.
My programmer is TL866A (now discontinued) but there is newer version - TL866II plus which supports even wider range of devices.
Reply 7 of 7, by treeman
yes I have the TL8662 plus
