First post, by MrFlibble
I found what appears to be a playable demo of Prehistorik 2 (at least, that's what the readme says) at cd.textfiles.com: pre2.zip
However I can't make it run in DOSBox (0.74, Linux 64-bit). When I run PRE.COM it just shows the DOS command prompt cursor and nothing happens at all. I tried loadfix -25, setting machine to vgaonly, forcing normal core and max cycles, no effect.
DOS Games Archive | Free open source games | RGB Classic Games
Reply 1 of 8, by ripsaw8080
Rank DOSBox Author
DOSBox Author
This one has very twisted protection, and it may require floppy controller hardware that DOSBox does not emulate, not sure.
Try this: TYPE PRE.COM (seriously 😀 )
Also, see this thread: Knight Force copy protection
Reply 2 of 8, by konc
Nice find! First time I hear about this.
You are correct, it doesn't run on DOSBox (0.74 Linux or 0.74-2 Windows). I tried it on a 386 with the exact same behavior. Then I just held shift key down to do a clean boot (MS DOS 6.22 with EMM386 and everything commonly ran on a 386 of that time) and...
891.94 KiB
And after finishing 1st level you get
57.11 KiB
Reply 3 of 8, by ripsaw8080
Rank DOSBox Author
DOSBox Author
It has the expected anti-debugger tactic of prefetch tricks, but for some reason cputype=386_prefetch is not enough to get it running. I'll investigate that later.
For now, I've attached the demo's executable with the protection wrapper removed, which DOSBox and other systems will find easier to digest, and it also facilitates nosing around in the game's code for anyone interested in that kind of thing. 😉
    pre2exe.zip
    26.51 KiB
    92 downloads
    unwrapped executable
Reply 6 of 8, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The original form of the Prehistorik 2 demo is fixed in SVN as of r4201 when using the cputype=386_prefetch setting, but the unwrapped executable in my previous comment can still be useful for 0.74(-2).
Reply 7 of 8, by Calvero
Nice find, indeed.
The overview map looks different, the font on the Enter code looks different. There's no audio.
Pressing left ctrl + left alt + w already shows a hidden credit screen.
It looks like they where also planning an EGA version.
Reply 8 of 8, by Akuma
Good for its day, now not so much, I doubt you had any problems unpacking it 😉
On that topic, I have a small collection (300+) packers and unpackers if you want them.
