First post, by Mackya
Hi everyone,
First post, but I am out of ideas, so apologies for a help request as my first one.
I am building a PII system, and it is vexing me terribly. It is a Matsonic MS-7380SG Slot 1 Motherboard (ATX) with a Pentium II 450mhz CPU.
300 Watt ATX Power Supply, on board sound and video, and 512MB of RAM.
When I power on, the system beings to POST then immediately shuts off. Ocassionally it will stay on for 8 seconds or so and I can see AWARD BIOS, Pentium 2 - 450mhz.
The longest it powered on it had no warning beep, or anything. When it powers on it gives the usual all clear beep, then either a cut off beep or nothing.
Things I have tried so far:
- Replacing CMOS battery
- Reseating CPU
- Reseating RAM
- Swapping RAM
- Swapping 300 Watt Power Supply with a brand new 600 Watt Power Supply
- Disconnecting everything and incrementally reconnecting
- Looking for bad solder joints or broken traces (none found)
Any ideas? 🙁
Thank you!
