First post, by Nvm1
Dear Vogoners,
For a few weeks I received a mainboard with a strange layout for the cachesockets.
I attached a few photo's below, watch the keying of the socket in the corner of the motherboard.
The attachment IMG_20190326_232506.jpg is no longer available
The attachment IMG_20190326_232825.jpg is no longer available
The attachment IMG_20190326_232839.jpg is no longer available
The attachment IMG_20190326_232910.jpg is no longer available
The last socket in the row with 5 cacheships (in the corner of the motherboard) is flipped/180degrees turned.
My question is; how can I check if the orientation of the socket that is flipped is correct?
Is it possible to check this with my multimeter on certain legs of the socket?
This because I want to prevent frying the board of my cache chips trying to get this motherboard alive again.
Second question is: The odin RTC module seems to be dead flat. What pins do I need to connect a battery holder to to reactivate the unit?
I know there is a thread about it but sofar I found 20 topics with people that either designed replacements or simply did mod their RTC..
Reply 1 of 12, by rasz_pl
yes, power and ground are easy to find (opposite corners)
https://github.com/raszpl/FIC-486-GAC-2-Cache-Module for AT&T Globalyst
https://github.com/raszpl/386RC-16 memory board
https://github.com/raszpl/440BX Reference Design adapted to Kicad
https://github.com/raszpl/Zenith_ZBIOS MFM-300 Monitor
Reply 2 of 12, by Nvm1
Okay, that sounds promising. What corner is/should be ground and which one power? If I know which leg in relation to the keying of the cachechip is what I can probe them.
Reply 3 of 12, by GigAHerZ
Nvm1, google the datasheet of your cache chips and you'll find the pinout.
A little about software engineering: https://byteaether.github.io/
Reply 6 of 12, by Nvm1
Anonymous Coward wrote:
Socket4 board?
Yes, it looks a bit like a TCM PCI58AL but the layout differs in alot of places..
And I only get a reading on the diagnostics card when I remove the RAM..
Either the empty Odin is causing this or the empty cache slots. Problem is that I can't find an external battery header which would solve one problem really easy.
Reply 7 of 12, by manuelink64
Hi:
With a multimeter, test continuity between all of "pin14" on the dip sockets (without the cache chip) and the main ground of the board.
if all make the beep/buzz sound you are discover the "polarity" of the chip.
good luck. 😎
[Unisys CWP] [CPU] AMD-X5-133ADZ [RAM] 64 MB (4x36) FPM [HDD] Seagate 8.4GB [Audio] SB16 SCSI 2 (CT1770) [Video] ATI Mach64VT2 [OS] Windows 95 OSR2.5
Reply 8 of 12, by Nvm1
manuelink64 wrote:
Hi: […]
Hi:
good luck. 😎
Thanks Manuelink64, will test it Friday evening. As soon as that is finished I am going to look into powering the RTC module somehow.
Still I find it strange that without cache, but with CPU, RAM, Keyboard and a working VGA installed I get no post codes on my diagnostics card.
The only way to get a code is by removing the RAM, then it is stuck at C1/bE
Should it not atleast give some codes with working FPM ram installed?
Edit:
I did test the cache module sockets, and they all have the orientation in the same way. The keying of the last slot is also incorrect 😠
I tried with 3 sets of known good FPM ram now, + cpu + vga card, but I cannot get it to boot/show any sign of life.
What else can cause this? The diagnostics card only gives numbers if I remove all RAM from the system...
Reply 9 of 12, by Nvm1
Just discovered a bent ISA pin that touched another pin, no more time to straighten it but will test tomorrow further.
Reply 10 of 12, by manuelink64
Different approach, try to find the 5VDC (or VCC) pin on all socket.
Good luck! 😊
Reply 11 of 12, by Nvm1
manuelink64 wrote:
Different approach, try to find the 5VDC (or VCC) pin on all socket. […]
Good luck! 😊
Thanks Manuel, I figured out the orientation already with your last tip.
And I just fixed the bent ISA pin but putting an old credit card between it to bend it back and then push it with my plastic spatula back in shape.
I found a broken resistor at the edge of the board, gonna solder a replacement in and then try again!
The isa post card now gives codes, so I am on the right way! 😀
Up to the next update on this weird board..
Reply 12 of 12, by manuelink64
Nvm1 wrote:
Thanks Manuel, I figured out the orientation already with your last tip. And I just fixed the bent ISA pin but putting an old cr […]
You're welcome! 😎
