First post, by boratintheuk
I have a little Pentium box running Windows 95 with built in Ethernet, connected to my network. It only has a 3 1/2 inch drive and no CD-ROM, so getting larger software on it is a pain. The IDE bus accepts only one drive and the sole ISA slot is occupied by a sound card. It is connected to the internet and It has Internet Explorer 2 but that software is pretty much incapable of opening any website whatsoever. I'd like to transfer files to it somehow, be it over LAN from my modern Windows 10 machine or over the internet. Any help would be appropriated.
Anyone curious the machine is a UNISYS CWD-5001
Reply 1 of 32, by bjwil1991
Make sure that on your Windows 95 and modern Windows 10 machines have the same usernames and passwords. Also, on Windows 10, it'll have a hard time contacting the Windows 95 machine for some odd reason. Make sure you enable the file sharing on Windows 95, create a new folder, and share it as full access.
For me, I use my Windows 7 laptop or my XP machines to copy files to my Windows 9x machines that are on the network at home, or my Windows 10 desktop as my Windows 10 laptop refuses to connect to the Windows 9x machines for no reason. For peer-to-peer connections, such as connecting the Windows 95 machine to the Windows 10 machine, you would need either a crossover cable or a switch to hook up the machines and setup the Windows 10 machine with an IP address and Windows 95 with the IP address and the gateway with the IP address from the Windows 10 machine.
Reply 2 of 32, by Jo22
Windows 98 PC suddenly stopped appearing in the Network on my main (Windows 7) PC
Reply 4 of 32, by bjwil1991
Didn't think of that. Good idea for using FTP. I might set up a NAS system sometime with FTP so I can copy files to the server and copy from the server to the client machine.
Reply 5 of 32, by Jo22
Yeah, just use FTP.. Or punch cards.
Reply 7 of 32, by dr.zeissler
There is no need of FTP.
I connect all my machine from 286 upwards and macs from lc475 upwards to my NAS in order to transfer files.
In plain Dos I use the MSClinet30 (TCP/IP) and TCP/IP is installed within W3x/9x and AppleTalk for the macs.
I use my unisys 486 too. Here is what I have connected it to:
UNISYS-CWD486
- Serial1 => AMIGA2000 AmigaExplorer
- Serial2 => Tandy1000 (via interlink/interserv)
- Paralel => Switchbox 1. Covox 2. Commodore 1541 XA-Cable 3. ZipDrive 4. LPT to MegaSTE
- ESS-Soundcard => Midi => MT-32/CM32L/SC55
- LAN Onboard => NAS 8TB
The Unisys can boot into:
- MSDOS Win1x2x3x/Gem/Geos etc.
- WIN95A
- WARP3
- NT351
You see I can transfer to nearly every machine on my setup with this little beast.
One thing does indeed not work, because of the small cpu and small lan power.
I can not use it to create floppys for my older retro-machines with the software from bu22.
It's far too slow to browse through the game-disks with the screenshots.
Using a hosted website on my NAS is also way too slow for that purpose.
https://www.flickr.com/photos/94839221@N05/al … 157683681646872
Reply 10 of 32, by dr.zeissler
One interesting thing to point out.
I use an old firmware for my NAS because synology changed the lanman to only accept passwords to be sent crypted.
If I upgrade to the newer firmware I can no longer connect via lanman and tcpip.
In that case and perhaps with a newer OS like Win7, I think then you are better with a ftp program.
Reply 11 of 32, by 1541
@Dr.Zeissler: In order to connect to Synology with SMB and a crypted password, you need to follow this approach:
Re: Adding my 486 to my Network
If you come across this screen ("No permission to access resource") upon writing from Win9x to another ressource, you can try to install the NTLM 2 authentication for Windows 9x/NT (DSclient.exe).
Follow this approach: https://translate.google.com/translate?hl=&sl … k-zugreifen.htm
(The "SMB1" option has to be enabled in the Synology NAS of course)
💾 Windows 9x resources (drivers, tools, NUSB,...) 💾
Reply 12 of 32, by keenmaster486
A USB PCI card might be an option. You could use XUSBSUPP to get the USB mass storage drivers on Windows 95.
Alternatively, yes, an FTP server is great.
Or - if you want to use MS-compatible network shares, I know that modern Linux with Samba can create and use Win9x-compatible shares, but modern MacOS or Windows 10 has trouble.
World's foremost 486 enjoyer.
Reply 13 of 32, by Gered
This is exactly what I do. I find it to be especially ideal with Win 95/98 machines using something like a 3Com 3C509 network card which doesn't require any additional drivers after a base Windows install. This allows me to immediately mount the Samba drive in Win 95/98 to grab the rest of the drivers and software I want to install, no mucking about with any configs or USB, CDs, CF cards, etc, etc.
486DX2-66/16MB/S3 Trio32 VLB/SBPro2/GUS
P233 MMX/64MB/Voodoo2/Matrox/YMF719/GUS CD3
Duron 800/256MB/Savage4 Pro/SBLive (IN PROGRESS)
Toshiba 430CDT
Reply 14 of 32, by boratintheuk
I didn't even consider FTP!!
I just setup a little server with Filezilla and was able to access it over the network with ftp.exe on the Windows 95 machine. Thanks for the tips guys.
Reply 15 of 32, by dionb
Also works fine & very easily under dos, look for the mTCP suite. Even something as old as an XT (or indeed PC Jr 😉 ) will happily share files with your server.
Reply 17 of 32, by Jo22
^Webservers are apparently very easy to implement. I wouldn't be surprised if someone will made one for the i4040 someday.
Here's an old link to the PICserver, running of a very old PIC controller chip.^^
https://web.archive.org/web/20000611144629/ht … wpic/source.htm
    picserv1.zip
    119.24 KiB
    125 downloads
    another pic server (?)
Reply 19 of 32, by Jo22
Yes, you're right - that's one important part of it. I hope boratintheuk gets it working and wish him good luck! 😀
If not, he can try the the other solutions the other nice Vogons users mentioned before.
In either case, let's don't desperate. We're are / he is not lone with that issue. Lot's of people have and had it before.
Btw, there are two more ideas that come to mind. He can use a Virtual Machine with an older copy of Windows
(WfW 3.11, Win 2k etc) with networking & folder sharing enabled. This will act as a bridge between old an new.
Or simple get an old or cheap Raspberry Pi and let it be the server for the vintage network.
Since it usually is Linux or RISC OS based, there are less security issues, too. 😀
Edit: Small edits. Sorry, I'm a bit sleepy, hah. 😅
Edit: A few more.
Edit: Here's a link to an issue (#80) of Raspberry PI magazine.
On Page 44, there's a tutorial that teaches how to build a Samba/CIFS file server..
