First post, by TheMLGladiator
Currently I have my Voodoo 2 hooked up to a "test bench" instead of the CRT that I normally use. After installing the latest reference drivers, I installed gl quake and noticed scan lines on my screen when running it. Is this normal behavior on an LCD?
Reply 1 of 6, by leileilol
Are these actual scanlines or are you just noticing the filter process blurring the dither into horizontal lines (which is normal)?
Reply 2 of 6, by doaks80
Bump up the resolution. You need to use command line arguments. E.g. -width 1024 -height 768. See what happens.
k6-3+ 400 / s3 virge DX+voodoo1 / awe32(32mb)
via c3 866 / s3 savage4+voodoo2 sli / audigy1+awe64(8mb)
athlon xp 3200+ / voodoo5 5500 / diamond mx300
pentium4 3400 / geforce fx5950U / audigy2 ZS
core2duo E8500 / radeon HD5850 / x-fi titanium
Reply 3 of 6, by leileilol
It would crash since a single Voodoo2 is implied.
Reply 4 of 6, by Parts man
Its been a long time since I played quake 2, but I recall it defaults to a rather low resolution. Try setting it to 800x600.
Also most lcd's scall poorly.
Reply 5 of 6, by TheMLGladiator
It's probably the scaling that's the issue. The system is now hooked up to a CRT and is getting solid performance in NFS high stakes (PII 400 MHz, 384 MB PC-100 RAM).
Reply 6 of 6, by 386SX
Add-in cards with vga passthrough cables always gave me quality problems with LCDs. Same things for the Dxr3 decoder cards.
