First post, by Logan50
Motherboard: not sure how to find that out.
Processor type and speed: Pentium 4 1.8 GHz
Amount and type of RAM: 512MB PC800 RDRAM
Operating system: Windows XP Professional
Description of problem:
😕 I've been trying to install dosbox in order to run Elderscrolls: Arena, but everytime I run the installer (DOSBox0.60-win32-installer.exe, DOSBox0.61-win32-installer.exe, or DOSBox0.61-win32-installer.exe) it give me this message: The NTVDM CPU has encountered an illegal instruction.
CS:0540 IP:0119 OP:65 63 74 20 61 Choose 'Close' to terminate the application.
If I choose close, it closes. If I choose ignore, it says the same, except IP:011a OP:63 74 20 61 20. If I choose ignore again, it closes.
WTF is going on?
(And no, I haven't read the README file, because I can't until it installs it)
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
either something corrupts your downloads or you have a seriously broken windows installation.
Water flows down the stream
Reply 2 of 5, by Logan50
I've been getting the different versions from here:
http://prdownloads.sourceforge.net/dosbox
is there another place to get them?
And how am I supposed to install it? Just double-click on the file, or do I actually have to start in the DOS prompt or one of those other start-up options?
Reply 3 of 5, by Logan50
Is that a polite way of saying sh-- rolls downhill?
Reply 4 of 5, by diamond204
Disable all security and pop up blockers, and download. Fixed it for me. The file should be 822k (not 16k or something small like that - that is caused by security)
Reply 5 of 5, by Logan50
Wow. Thx. That actually worked. Who knew?
Never woulda guessed getright was causing the problem.
