First post, by Guest
Guest
Offline
ancient art of war is not working anymore in dosbox 62, help !!!! pleease someone
are you certain ? I just tested both the vga and the cga version.
Worked fine
Water flows down the stream
ok, it is my fault
my version using ramkey memory resident crack (working in dosbox61)
now i patch my war.exe using patcher v6.5
thanks for your response
and thanks for a GREAT DOS EMULATOR !!!!!!
