First post, by user33331
 - Member
Hello ( Installing a 3.5" floppy drive to an old I/0 card cable 386/486 ? )
Beginner amateur questions:
1.) What is the name of this "old-style floppy" I/0-cable with 4pcs of connectors ? ( See picture )
2.) Can I just use a regular modern floppy cable with only a 1pc connector ?
I can't get the 3.5" 1.44mb floppy to work:
- Must I set it as a *Floppy A* or *Floppy B* in BIOS ?
- Do I need drivers ?
- It says "Not ready reading drive A Abort, Retry, Fail?".
https://en.wikipedia.org/wiki/Abort,_Retry,_Fail%3F
- Which way the floppy connector goes ? ( See picture )
