RS-232 vs Bus Mouse
First post, by Jo22
Hi everyone, just noticed a thread over there at vcfed.org -> http://www.vcfed.org/forum/showthread.php?69372-Mouse-for-XT
This makes mew wonder, is a bus mouse less demanding than a serial mouse ?
Reply 1 of 4, by weldum
the thing is that both bus mouse and ps/2 mouse uses a chip that's constantly polling the bus to see changes in the mouse movements. a serial mouse depends on the processor to do so, effectively being a little bit more demanding
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 2 of 4, by Jo22
Oh. thanks for the feedback. Bus mice were a bit before my time, so I liked to know. 😊
By the way, maybe you know this, too - Is the bus mouse controller polling only or also using interrupts ?
If so, is it also as "interrupting" as much as the 8250/16450 FiFOs do or rather comparable to the less frequently interrupting 16550 ?
Why I ask..: I believe there are Atari ST to Serial Mouse adapters out there (uC based)..
So would like to know if it would make sense to rebuild a bus mouse controller card, but with a built-in Atari/Bus mouse converter.
Once workingn, on the mouse side, the same serial-PS/2 hybrid mice could be used as with the other RS232-to-PS/2 projects.
Reply 3 of 4, by weldum
these things are a bit outside my knowledge, maybe someone will answer the question better
Reply 4 of 4, by Jo22
That's okay, don't worry. Thanks, for the reply, also. I'm just curious, but don't know either.
