What cable is this?
First post, by xjas
Here's a mystery USB cable I found in my drawer of such things. Wondering if one of you can identify it, so I can decide if I should hoard it or toss it out 😜
It's the size of a mini-USB connector and pretty much looks like one except for the corners. The other end is a standard USB A (probably 2.0) plug.
The attachment CameraZOOM-20190421173241046.jpg is no longer available
I suspect it's for a digital camera or maybe handheld console, but I can't figure out what.
Things it is definitely not:
DisplayPort - looks similar, way too small
Mini DisplayPort
Apple mini-VGA or mini-DVI
Any kind of firewire
Nint*ndo DS, DS Lite, or DSi
Sony PSP (uses a standard mini-USB from what I can tell), or PS Vita (very different)
I'm stumped!
Reply 1 of 8, by chrismeyer6
If I'm remembering correctly I had a camera back in the day with a similar looking cable
Reply 2 of 8, by jmarsh
It's just regular mini usb, phone manufacturers sometimes used them if the ports had extra functionality built-in.
Reply 3 of 8, by Jo22
No idea what it is. Perhaps it's a custom connector. The cable could have an USB-Serial chip built-in (TTL, not RS232).
Some cellphone adapter cables from the early 2000s were like that, if memory serves.
Reply 4 of 8, by Merovign
No that's not a regular USB mini, the USB mini has an indent on both sides. That looks more like a DisplayPort but too small. Because of the indent on one side but not the other. And it doesn't have an L-shaped center.
It looks more like a micro-DVI, but less pins and the micro also has indents on both sides.
chrismeyer6's guess is probably right, it's probably a proprietary camera connection. Might want to ask on the recent "post pics from old cameras" post.
*Too* *many* *things*!
Reply 5 of 8, by pete8475
Can you post a pic with both ends visible near each other? I think people are underestimating the size of that connector.
Reply 6 of 8, by jmarsh
Yes, but the manufacturers would purposefully leave one of the indents off so the cable would only fit in "their" port. HTC called theirs "ExtUSB" IIRC.
If the cable actually had something interesting on the other end (like a headphone jack or usb hub) it would be worth keeping, but otherwise it's identical to a usb mini cable.
Reply 7 of 8, by xjas
Thanks guys!
This tipped me off that the HTC Dream / Google G1 / aka the First Android Phone Ever has this port. I actually have one of those, and used it heavily until ~2014, but I don't think I ever had this style of cable for it; I always just used a mini USB one. I bought that phone used without accessories and this cable was in a sealed package, so I must have picked it up elsewhere, god-knows-when.
Guess I'll hang onto the cable in case the Dream/G1 becomes a valuable collectors item some day, or I dig it out and start using it again. 😜
FWIW I'd already gone through all my cameras and didn't find a match, although it's entirely possible there is one that uses it; it was in my drawer of "camera stuff."
Reply 8 of 8, by wiretap
Yea a lot of early smart phones used that USB interface. My HTC TyTN and TyTN II used it. (Windows Mobile 5 and 6.x phones) I believe I also had a Canon(?) point and shoot camera that used it around the same time period.
Example:
My Github
Circuit Board Repair Manuals
