Dosbox Debugger for MAcOS 10.14
General information and assistance with DOSBox.
Postby robbo007 » 2019-4-22 @ 22:05
Hi, does anyone have the compiled copy of Dosbox with the debugger enabled for MAcOS 10.14.x? I'm trying to compile but get errors. Can't seem to get it to work on Windows XP either? I get a SDL.dll error.
Cheers,
Rob
User avatar
robbo007
Re: Dosbox Debugger for MAcOS 10.14
Postby Qbix » 2019-4-23 @ 05:40
on XP, the debugger version can be placed in the same folder as normal debugger and then there should be no problems, as it uses the same dll files.
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby robbo007 » 2019-4-23 @ 19:58
ok, Do I need to install and SDL libraries on XP? I've tried registering the sdl.dll with reg32svr but it does not work. I've placed the dosbox debugger in Windwos/system32 where the windows debug.exe is and I still get the same error about the sdl.dll.
User avatar
robbo007
Postby Qbix » 2019-4-23 @ 20:04
No I added a debugger to many in my previous reply.
The debugger version should be placed in the same folder as the normal dosbox version.
User avatar
Qbix
DOSBox Author
Postby robbo007 » 2019-4-23 @ 21:08
got it thanks :) Now lets debug :)
User avatar
robbo007
Return to DOSBox General
Who is online
Users browsing this forum: No registered users and 3 guests
