First post, by overdrive333
overdrive333
Offline
Mobo - microstar MS-5184 ( Via MVP3). 200MMX works 100% stable as 100x3 and even 112x2.5 on it but not this K6-2. It hangs while loading OS even as 100x2.5 regardless of voltage. Max stable FSB is 95mhz, so I had to stop at 95*3.5=333 😒 Is it normal for 66FSB K6-2's? What prevents him from functioning on 100fsb?
