First post, by retropol
Hi Guys,
I am trying to find gfx drivers for TSENG ET4000AX - for dos, win3.1 and win9x
I went here, but no idea what (if there any) are for win9x
https://www.vogonsdrivers.com/index.php?catid=63
Can you help in getting drivers for dos,win3.11 and win9x?
No success when searching net, anything found - are old links (dead already).
Reply 1 of 7, by elianda
If you search here for 'et4000' it gives enough results: https://retronn.de/imports/search.html
However this is also a good starter: ftp://retronn.de/driver/TSENG/
Youtube Channel
Reply 2 of 7, by dr.zeissler
@elianda
do you know a way (tool) to calibrate the vga signal to match textmode-vga and vga-lowres on a tft?
all et4k cards have 5-7 mm image moved to the right in vga-lowres (320x200@256colors). (EGA Lowres is centered though)
ati mach cards are perfectly centered between textmode (80x25) and ega/vga lowres.
Thx
Doc
Reply 3 of 7, by retropol
elianda, thank you very much, but... there is no win9x driver...
Reply 4 of 7, by elianda
The reason is simple, Win9x has the ET4000AX drivers included.
In Win95_05.cab is tseng.drv and tseng.vxd
It is linked in msdisp.inf.
If Win9x did not detect it, go to the device manager, standard vga driver, update, choose your own and select TSENG/ET4000 from the list of display drivers.
Youtube Channel
Reply 5 of 7, by elianda
dr.zeissler wrote:
@elianda do you know a way (tool) to calibrate the vga signal to match textmode-vga and vga-lowres on a tft? all et4k cards have […]
@elianda
Some older cards seem to have a different video timing in these modes. This can also be seen with better capture cards.
The only program that comes to my mind that allows to change display timing in DOS is VGAMODE, the same where you can change 1024x768 from 43 Hz interlaced to 60 Hz progressive. I have not tried to tackle that problem though as it would require a card specific tool for each card.
In the long run it might be possible to patch the BIOS such way that it sets the same timing for these modes. (If the hardware supports it)
Youtube Channel
Reply 6 of 7, by dr.zeissler
There are some cards/chips that stand out on this.
Intel IGP's are nearly 100% centered in all modes.
Voodoo3 is also great.
Matrox G200 is good too. On windows you can correct the image in every resolution and bitdeph.
R7000 is also great.
Geforce-Cards are mostly bad in this.
I remember the setup-dialog on turrican2-tff. it lets you config the image-output.
the easiest way in my opion is to patch the textmode-output.
Reply 7 of 7, by dr.zeissler
For me a a retro gamer it's VERY VERY annoying to not to have a centered output between text- and gfx-mode.
it would be a BIG thing if I could correct this.
