First post, by hydroksyde
So I have this Asus A7V333 board I was intending to use for an AthlonXP build, but after a screwdriver mishap while removing the CPU cooler it no longer POSTs and reports "system failed memory test" from the PC speaker.
Had a colleague of mine take a look under the microscope and he noticed RN36 has a crack. I'm not entirely sure what this is but given the other side, and other nearby similar looking components read less than 1 ohm between opposing pins, I suspect it might be a 0 ohm resistor array. Does anybody know if this is correct?
