First post, by retro games 100
Can someone please tell me what the chips do on the Maui? I think the ones very close to the SIMM RAM are onboard RAM, although it's interesting that further away from that area (not pictured) there is another small RAM IC. I think the chip next to this area is the 2MB ROM chip. The large chip I guess is the main sound processing unit? I guess the Motorola? chip is the bus interface chip? What does the smaller wavefront chip do please? Also, as there are no sound effects from this unit, I guess there is no codec? Any comments would be gratefully received - thanks a lot! 😀 PS...where is the DAC? Thanks.
503.38 KiB
Reply 1 of 11, by peklop
Motorola CPU datasheet:
https://www.nxp.com/docs/en/product-brief/MC68SEC000.pdf
WafeFront ICS2115 Synthesizer:
https://4donline.ihs.com/images/VipMasterIC/I … SID002-G-51.pdf
WaveFront ICS2116 Interface component
https://4donline.ihs.com/images/VipMasterIC/I … ID001-G-171.pdf
WAVEROM ICS2122M is ROM
ICS2494 is memory clock generator
http://www.transputer.net/mtw/rg-750/doc/video/ics2494.pdf
3x Toshiba TC514256AJ-70 are 128kB DRAM memory chips.
https://wakamatsu.co.jp/waka/TOSHD003-A-185.pdf
DAC is U36 under two capacitors?
Reply 2 of 11, by peklop
BTW why some Maui 1.0 cards have and some don't have WaveBlaster connector?
If is one striped-down variant, are all with same waveROM size?
(when Tropez/TBS-2001/TBS-2000/Tropez32 existing with 4MB, 2MB or 1MB ROMs)
Reply 3 of 11, by cyclone3d
I saw in another thread that that is not actually a waveblaster connector, but actually an input so you can hook up the Maui to another sound card's waveblaster header so you can run the Maui as if it were a daughtercard.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 11, by Rawit
Only time I saw a picture of a Maui with the header was when somebody soldered one to try out what it does. I thought it was an abandoned idea and that there was only one revision.
Do you have any docs/info on this? AFAIK the Tropez classic has the same ROM as the Maui, 2MB. Second Tropez classic revision has a pop in the left channel in combination with some mainboards.
YouTube
Reply 8 of 11, by yawetaG
There's also a special Turtle Beach daughterboard called Rio that can be hooked up to it. See Turtle beach Rio midi daughterboard
Reply 10 of 11, by retrosoundi
Great card with great possibilities its "only " a midi card but there is a wemp96 player for mods in dos Wavefront Extended Module Player v0.96 by Daniel Baum .
277.4 KiB
In the manulal its says that you can connect this card to a sound card with the 26 pin ribbon cable to replace its synth
In games Its easier to have maui installed with other sound card and plug the maui sound out to a sound in or auxilliary of this other card and make changes in games setup for midi sounds .
You can find info in the internet that:
SECTION 2: Package Changes
2a) Changes to the Card
The first batch of Maui's had the WaveBlaster connector header,
however, subsequent Maui's did not have this connector. The explanation
from Turtle Beach was that Creative Labs changed the WaveBlaster
specifications at the last minute so the WaveBlaster connector was removed.
For those of you who want WaveBlaster daughtercards, look into Turtle
Beach's Rio card.
2b Changes to the Manual (v1.0)
Since the WaveBlaster header is no longer there, the references to
the WaveBlaster connector and "Internal Serial MIDI Interface" are fairly
obsolete. As far as I know, no one has tried to make their own patch cable
to use the WaveBlaster header circuitry on the Maui.
The JP2 Port settings on page 12 to set the Base Address Maui uses is
incorrect. The setting for port 230h is correct, but the setting for port 210h
should show all jumpers closed.
Reply 11 of 11, by GL1zdA
Did anyone try a daughterboard with the Maui's wave blaster header? I did a "mind" experiment, and if you connect a "proper" waveblaster header (like on the Tahiti mentioned in the manual) via an "unpatched" ribbon cable, you are connecting them 1:1. Given they suggested connecting them this way means: the "voltage" pins are in the same place as in a normal waveblaster header (nothing happens if you connect them together), but inputs and outputs are exchanged, since it should work like a waveblaster daughtercard when connected to a card with a "standard" waveblaster header.
I'm aware that daughtercards with a "reversed" or "mirrored" header existed, but I haven't really seen an explanation of what "reversed" means. Was the connector just on the opposite site? Were all pins mirrored? Or only the inputs and outputs?
getquake.gif | InfoWorld/PC Magazine Indices
