BIOFORGE Help
First post, by XulChris
How do I get bioforge to run?
running the bioforge.bat file from C: gives me subst errors in dosbox. If I try running bioforge.exe from A: I get a message saying I don't have enough disk space.
Supposedly it's possible to get this game running because other people have said it runs slow, I would like to just be able to get it started. Any help would be appreciated.
Running dosbox 0.62 on Fedora.
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
be sure the subst thingie uses:
syntax like this:
subst c: localtion
(note the :
Water flows down the stream
Reply 2 of 5, by XulChris
Qbix:
Here is the BAT file contents:
@echo off
subst a: /d
subst a: .
a:
bioforge.exe
c:
subst a: /d
echo on
DOSBox reports an error for every subst command given:
Removing drive not supported. Doing nothing.
SUBST failed. You either made an error in your commandline or the target drive is already used.
It's only possible to use SUBST on Local drives
Reply 3 of 5, by wd
Rank DOSBox Author
DOSBox Author
You can mount the directory bioforge resides in as a:
(sth like mount a c:\games\bioforge) and start it with
bioforge.exe (from a:), or better remove the .bat-files
and start it/run install as normal.
wd
Reply 4 of 5, by wd
Rank DOSBox Author
DOSBox Author
wow, a: in parantheses looks great 😀
have to remember the preview-button next time.........
Reply 5 of 5, by XulChris
This work-around works, thanks.
