First post, by u1comp1
When you run DirectQ v1.9.0 ​​in Windows 10 v1903, a black screen appears. The game itself works. Exit the game can be to the touch, for example by pressing F10. After exiting the game on the desktop, the image does not appear (black screen). Only by touch can you complete the work, for example, press ALT + F4 and ENTER. After this, the PC will turn off and if later it is turned on again, then Windows 10 will start normally and the desktop will be normally visible. In the shortcut for installing compatibility with different operating systems or disabling optimization on the whole screen, do not give anything. In Windows 10 v1809, everything worked fine. It seems that some kind of DirectQ v1.9.0 ​​incompatibility with Windows 10 version 1903 has appeared. You can check it yourself: https://www.quaddicted.com/files/engines/directq/
What can you suggest or advise? Maybe there is some kind of fix?
Reply 1 of 2, by leileilol
Did you install DirectX9 at all? Win10 doesn't come with that and DirectQ is purely a D3D9 renderer.
Reply 2 of 2, by u1comp1
I managed to run in Windows 10 v1903 DirectQ. The properly working version was DirectQ v1.8.7 RC3 Executable.
