First post, by nicoliani
Using the newest version of Dosbox.
I want to get this game in full screan mode, not using ALT-ENTER, becouse the screen then get's to big and u can't see the game time etc.
An overview of the commandline options you can give to DOSBox:
dosbox [name] [-exit] [-c command] [-fullscreen] [-conf congfigfile]
[-lang languagefile] [-machine machinetype] [-noconsole]
[-startmapper]
-fullscreen
Starts dosbox in fullscreen mode.
I don't get this what exactly should I time at the dospromt the get DosBox in fullscrern?
I have tried with:
(c:\)dosbox fullscreen
Reply 1 of 1, by priestlyboy
If you don't have a DOSBox.conf. You can easily make one by booting into DOSBox and then typing config -writeconf DOSBox.conf. Then open DOSBox.conf in your favorite notepad-like program and change the following settings.
The "overscaling" sounds like fullfixed= needs to be changed from false to true in your DOSBox.conf.
That should fix the "too large" problem.
Now, if it looks too small when in fullscreen. *like a little box with a huge blackness around it*
Change the output= from surface to overlay.
That should fix that.
Then you should be able to use ALT-ENTER and have it look.. "right".
I hope that helps.
Refer to the DOSBox WIKI. It has a wealth of information for every new user.
Ieremiou
Helping Debug DOSBox.
