First post, by borgie83
Hey guys. So I have a Sound Blaster 16 CT1740 which was getting quite hot and also not playing sound out of the left channel. Due to this I replaced the Dac, Amp, Yamaha OPL Sound Chip and 2 larger capacitors located near the volume wheel. All with new parts. I haven't tested it yet as wanted to know if I should also replace the 2 voltage regulators first? Just don't want to power it up and fry the amp etc. Basically I'd like to know if the voltage regulators would cause a sound card to get hot and fry the amp.
Reply 2 of 9, by Jo22
Hi, not sure what to say. 🙁 If an 78xx/79xx is faulty, it either shorts or passes the full voltage.
These voltage regulators aren't expensive and can be bought in your local electronics shop.
Just be sure to get the right parts. Some stabis can provide 0.5A, 1A or 1.5A (or 2A).
So also better check the suffix, (ex. 7805 vs 7805CT vs 7805G etc.)
Also keep in mind that pinout of 78xx and 79xx is not the same.
Reply 3 of 9, by borgie83
Jo22 wrote:
Hi, not sure what to say. :( If an 78xx/79xx is faulty, it either shorts or passes the full voltage. These voltage regulators ar […]
Apologies for the delay. The voltage regulators are as follows; AN7805 and AN7809. Both appear to be positive voltage regulators? Could be wrong though. Just thought the sound blasters had 1 positive and 1 negative? 1st VR is 5V and the 2nd is 9V. Both 1A.
Reply 4 of 9, by Jo22
Hi, yes, seems right to m. The older 8-Bit cards (SB1.x-2) also had -5v, I believe.
Reply 5 of 9, by borgie83
So 2 positive voltage regulators being a 7805 and 7809 would be fine to use? Also, is higher or lower ripple rejection better?
Reply 6 of 9, by Tiido
Higher ripple rejection is better.
Negative regulator is a small transistor sized thing (TO92 package), 79L05 written on it.
Reply 7 of 9, by borgie83
Ok great. Thanks mate. What I'm confused about though is that my card appears to have 2 positive voltage regulators and yet I've read about there being 1 positive and 1 negative on Sound Blasters. I'll upload a photo on my voltage regulators for clarification.
    667.55 KiB
    CT1740 Voltage Regulators
Reply 8 of 9, by Tiido
5V one is for positive rails on the opamps and DAC+ADC stuff, -5V one for opamps negative rail and the 9V one is used for the speaker amplifier.
Reply 9 of 9, by Jo22
Sorry for not replying ealier. Also: Good luck! 😀
