First post, by Intel486dx33
What are the Keyboard Hotkeys to enable/disable “Turbo mode” on a Soyo motherboard ?
The Motherboard has Turbo LED but no turbo switch.
I am assuming it is enabled/disabled via the keyboard.
Super Socket 7 Motherboard manual:
http://www.motherboards.org/files/manuals/107/m5eh20.pdf
Reply 1 of 4, by gdjacobs
Most S7/SS7 motherboards with a turbo header leave it always on.
Reply 2 of 4, by Intel486dx33
So I would have to disable L1 cache in the bios settings ?
Would that change the status of the LED turbo light ?
Reply 3 of 4, by gdjacobs
No, it would not. The header is there for compatibility, strictly to power a clock speed indicator. SETMUL will be usable for quite a few socket 7 compatible CPUs, so L1 cache manipulation isn't the only method available.
Reply 4 of 4, by bbuchholtz
Most motherboards use the following keyboard combinations for enabling and disabling turbo:
Enable: [CRTL] [ALT] [+]
Disable: [CRTL] [ALT] [-]
-Brian
