First post, by RegTheEvil
I have a problem. I haven't figured out how to make my retro system boot into Windows after using the DOS Start Menu I just made. If I use these files (AUTOEXEC.BAT + CONFIG.SYS) for "Restart in MS-DOS mode" it works well but I would like to make it work without having to go to Windows before entering DOS Start Menu. If I copy these files into C root I can make the menu work almost completely but I can't boot into Windows. If I choose Windows "MENUITEM=37WIN, Start Windows" from DOS, I get a message "You are currently running in MS-DOS mode. Do you want to return to normal mode, to run Windows applications again [Enter=Y, Esc=N]?" If I press "y", computer reboots to the start of the menu. If I type "exit", I get nothing. If I type "win" after choosing any menuitem, I get the same message and I can press y to reboot back to DOS start menu. Menu stays on endless loop.
How can I make my DOS Start Menu behave correctly, and get into Windows from it?
AUTOEXEC.BAT
GoTo %config%
:11EMCYMF
LH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:OPTICAL
:12EMYMF
LH C:\DRIVERS\CTMOUSE.EXE /R2
:13EYMF
keyb su,,C:\WINDOWS\COMMAND\keyboard.sys
CD C:\DRIVERS\SND\YMF724\DS-XGYMF
setupds /s
DSDMA
set blaster=A220 I5 D1 T4 P330
CD C:\DOSGAMES
GoTo :TELEPORT
:14XMCYMF
:15XMYMF
:16XYMF
setupds /s
CD C:\DOSGAMES
GoTo :TELEPORT
:17CRUSAD
SET BLASTER=A220 I7 D1 H7 P330 T6
SET SBPCI=C:\DOSDRV
C:\DOSDRV\SBLOAD
C:\DOSDRV\SBINIT.COM
CD C:\DRIVERS\SND\YMF724\DS-XGCT
setupds /s
CD C:\DOSGAMES\CRUSADER
GoTo :TELEPORT
:21EMCCT
SET SBPCI=C:\DOSDRV
C:\DOSDRV\SBLOAD
setupds /s
CD C:\DOSGAMES
GoTo :TELEPORT
:22EMCT
SET SBPCI=C:\DOSDRV
C:\DOSDRV\SBLOAD
Show last 118 lines
setupds /s
CD C:\DOSGAMES
GoTo :TELEPORT
:23ECT
SET SBPCI=C:\DOSDRV
C:\DOSDRV\SBLOAD
setupds /s
CD C:\DOSGAMES
GoTo :TELEPORT
:24CMCYMF
setupds /s
CD C:\DOSGAMES
GoTo :TELEPORT
:25CMYMF
setupds /s
CD C:\DOSGAMES
GoTo :TELEPORT
:26CYMF
setupds /s
CD C:\DOSGAMES
GoTo :TELEPORT
:27ALADDI
SET SBPCI=C:\DOSDRV
C:\DOSDRV\SBLOAD
setupds /s
CD C:\DOSGAMES\ALADDIN
GoTo :TELEPORT
:31XMCVX
CD C:\DRIVERS\SND\YMF724\DS-XGCVX
setupds /s
SET BLASTER=A220 I7 D1 T2 P330
CD C:\DRIVERS\SND\CVX4\VSB
vsb /L1 /W /A /I7
CD C:\DOSGAMES
GoTo :TELEPORT
:32XCVX
setupds /s
CD CD C:\DRIVERS\SND\CVX4\VSB
vsb /L1 /W /A /I7
CD C:\DOSGAMES
GoTo :TELEPORT
:33CMCVX
setupds /s
vsb /L1 /W /A /I7
CD C:\DOSGAMES
GoTo :TELEPORT
:34CCVX
setupds /s
vsb /L1 /W /A /I7
CD C:\DOSGAMES
GoTo :TELEPORT
:35XMCVX
setupds /s
CD C:\DRIVERS\SND\CVX4\TEMU
temu /L1 /T44
CD C:\DOSGAMES
GoTo :TELEPORT
:36CCVX
setupds /s
temu /L1 /T44
CD C:\DOSGAMES
GoTo :TELEPORT
:37WIN
win
:TELEPORT
CONFIG.SYS
DOS=SINGLE
[COMMON]
DOS=HIGH,UMB,NOAUTO
FILES=40
BUFFERS=40
LASTDRIVE=H
[MENU]
MENUCOLOR=13,0
SUBMENU=EKA, Start DOS - Settings 1. . .
SUBMENU=TOKA, Start DOS - Settings 2. . .
SUBMENU=KOLMAS, Start DOS/Windows - Settings 3. . .
MENUDEFAULT=EKA,10
[EKA]
MENUITEM=11EMCYMF, Expanded memory + Mouse + CD-ROM (YMF724: Sound Blaster + FM)
MENUITEM=12EMYMF, Expanded memory + Mouse (YMF724: Sound Blaster + FM)
MENUITEM=13EYMF, Expanded memory (YMF724: Sound Blaster + FM)
MENUITEM=14XMCYMF, Extended memory + Mouse + CD-ROM (YMF724: FM)
MENUITEM=15XMYMF, Extended memory + Mouse (YMF724: FM)
MENUITEM=16XYMF, Extended memory (YMF724: FM)
MENUITEM=17CRUSAD, Crusader [EMM386 + Mouse + CD-ROM] HimemX: max 32000 (CT4810 & Y: FM)
SUBMENU=TOKA, -> Start DOS - Settings 2. . .
SUBMENU=KOLMAS, -> Start DOS/Windows - Settings 3. . .
MENUCOLOR=11,0
MENUDEFAULT=1EMCYMF,10
[TOKA]
MENUITEM=21EMCCT, Expanded memory + Mouse + CD-ROM (CT4810 & YMF724: FM)
MENUITEM=22EMCT, Expanded memory + Mouse (CT4810 & YMF724: FM)
MENUITEM=23ECT, Expanded memory (CT4810 & YMF724: FM)
MENUITEM=24CMCYMF, Conventional Memory only + Mouse + CD-ROM (YMF724: FM)
MENUITEM=25CMYMF, Conventional memory only + Mouse (YMF724: FM)
MENUITEM=26CYMF, Conventional memory only (YMF724: FM)
MENUITEM=27ALADDI, Aladdin [EMM386] HimemX: max 12800 (CT4810 & YMF724: FM)
SUBMENU=KOLMAS, -> Start DOS/Windows Settings 3. . .
SUBMENU=EKA, -> Start DOS - Settings 1. . .
MENUCOLOR=10,0
MENUDEFAULT=C,10
[KOLMAS]
MENUITEM=31XMCVX, Extended memory + Mouse (CVX4: VSB & YMF724: FM)
MENUITEM=32XCVX, Extended memory (CVX4: VSB & YMF724: FM)
MENUITEM=33CMCVX, Conventional memory only + Mouse (CVX4: VSB & YMF724: FM)
MENUITEM=34CCVX, Conventional memory only (CVX4: VSB & YMF724: FM)
MENUITEM=35XMCVX, Extended memory + Mouse (CVX4: TEMU & YMF724: FM)
MENUITEM=36CCVX, Conventional memory only (CVX4: TEMU & YMF724: FM)
MENUCOLOR=6,0
MENUDEFAULT=C,10
[11EMCYMF]
DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFF
DEVICE=C:\WINDOWS\EMM386.EXE RAM
DEVICEHIGH=C:\DRIVERS\VIDECDD.SYS /D:OPTICAL
[12EMYMF]
Show last 61 lines
[13EYMF]
[14XMCYMF]
[15XMYMF]
[16XYMF]
[17CRUSAD]
DEVICE=C:\DRIVERS\HIMEMX.EXE /MAX=32000
[21EMCCT]
[22EMCT]
[23ECT]
[24CMCYMF]
[25CMYMF]
[26CYMF]
[27ALADDI]
DEVICE=C:\DRIVERS\HIMEMX.EXE /MAX=12800
[31XMCVX]
[32XCVX]
[33CMCVX]
[34CCVX]
[35XMCVX]
[36CCVX]
[37WIN]
MSDOS.SYS
[Paths]
WinDir=C:\WINDOWS
WinBootDir=C:\WINDOWS
HostWinBootDrv=C
[Options]
BootMulti=1
BootGUI=0
DoubleBuffer=1
AutoScan=1
WinVer=4.10.2222
Logo=0
;The following lines are required for compatibility with other programs.
;Do not remove them (MSDOS.SYS needs to be >1024 bytes).
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxa
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxb
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxc
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxd
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxe
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxf
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxg
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxh
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxi
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxj
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxk
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxl
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxm
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxn
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxo
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxp
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxq
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxr
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxs
AT2 & other music made by me + miscellaneous stuff
Comics made by me
Reply 1 of 4, by zyga64
This behavior is caused by the very first line of config.sys:
DOS=SINGLE
Remove it, make it comment (; at the beginning of the line), or move to the subsection if it is really needed.
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-2@400 /64M /MGA-2064W+3dfx /YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 2 of 4, by RegTheEvil
Thanks, bud! 😀
I actually ended up removing [COMMON] section completely from my CONFIG.SYS file along with "DOS=SINGLE" line. I'm not sure if you meant this but this made it work all better. I haven't had issues under DOS yet and now I can type "win" in most situations or use the menu item directly going to Windows. If I have VSB or TEMU loaded, WIN command fails and I'm forced to reboot or shutdown but otherwise it seems to work just fine now.
In case anyone wonders why I added "setupds /s" line to my AUTOEXEC.BAT file under line ":37WIN"... Well if I use Windows DOS Box then I get quieter audio in Windows DOS Box if I don't load "setupds /s". I can only get louder audio on first run of any DOS application and only one DOS application per boot. I have no idea why only once with "setupds /s" loaded and not at all if "setupds /s" is missing from autoexec.bat. Also OPL sounds seem to be quieter in Windows DOS Box at all times no matter whether "setupds /s" is loaded or not but these minor issues probably remain for a very long time and have nothing to do with anything here. Besides under plain DOS, sounds work louder at all times, both digitized and OPL/FM/AdLib.
Here are my modified lines for both AUTOEXEC.BAT and CONFIG.SYS files in case anyone is having similar problems or is otherwise interested.
AUTOEXEC.BAT
GoTo %config%
:11EMCYMF
:12EMYMF
:13EYMF
setupds /s
DSDMA
CD C:\DOSGAMES
GoTo :TELEPORT
:14XMCYMF
:15XMYMF
:16XYMF
setupds /s
CD C:\DOSGAMES
GoTo :TELEPORT
:17CRUSAD
SET SBPCI=C:\DOSDRV
C:\DOSDRV\SBLOAD
setupds /s
GoTo :TELEPORT
:21EMCCT
SET SBPCI=C:\DOSDRV
C:\DOSDRV\SBLOAD
setupds /s
CD C:\DOSGAMES
GoTo :TELEPORT
:22EMCT
SET SBPCI=C:\DOSDRV
C:\DOSDRV\SBLOAD
Show last 122 lines
setupds /s
CD C:\DOSGAMES
GoTo :TELEPORT
:23ECT
SET SBPCI=C:\DOSDRV
C:\DOSDRV\SBLOAD
setupds /s
CD C:\DOSGAMES
GoTo :TELEPORT
:24CMCYMF
setupds /s
CD C:\DOSGAMES
GoTo :TELEPORT
:25CMYMF
setupds /s
CD C:\DOSGAMES
GoTo :TELEPORT
:26CYMF
setupds /s
CD C:\DOSGAMES
GoTo :TELEPORT
:27ALADDI
SET SBPCI=C:\DOSDRV
C:\DOSDRV\SBLOAD
setupds /s
GoTo :TELEPORT
:31XMCVX
setupds /s
vsb /L1 /W /A /I7
CD C:\DOSGAMES
GoTo :TELEPORT
:32XCVX
setupds /s
vsb /L1 /W /A /I7
CD C:\DOSGAMES
GoTo :TELEPORT
:33CMCVX
setupds /s
vsb /L1 /W /A /I7
CD C:\DOSGAMES
GoTo :TELEPORT
:34CCVX
setupds /s
vsb /L1 /W /A /I7
CD C:\DOSGAMES
GoTo :TELEPORT
:35XMCVX
setupds /s
temu /L1 /T44
CD C:\DOSGAMES
GoTo :TELEPORT
:36CCVX
setupds /s
temu /L1 /T44
CD C:\DOSGAMES
GoTo :TELEPORT
:37WIN
setupds /s
win
:TELEPORT
CONFIG.SYS
[MENU]
MENUCOLOR=13,0
MENUDEFAULT=EKA,10
[EKA]
MENUCOLOR=11,0
[TOKA]
MENUCOLOR=10,0
MENUDEFAULT=21EMCCT,10
[KOLMAS]
MENUITEM=37WIN, Start Windows ['setupds /s' prevents quiet audio in 1st DOS app run]
MENUCOLOR=6,0
MENUDEFAULT=31XMCVX,10
[11EMCYMF]
[12EMYMF]
[13EYMF]
[14XMCYMF]
Show last 54 lines
[15XMYMF]
[16XYMF]
[17CRUSAD]
[21EMCCT]
[22EMCT]
[23ECT]
[24CMCYMF]
[25CMYMF]
[26CYMF]
[27ALADDI]
[31XMCVX]
[32XCVX]
[33CMCVX]
[34CCVX]
[35XMCVX]
[36CCVX]
[37WIN]
Comics made by me
Reply 3 of 4, by dr_st
As usual, bloated config with 25 different options where you probably only need 2 or 3 (for the different sound cards, and maybe for a specific game that has issues that cannot be solved in other ways). Glad it works for you, though.
Reply 4 of 4, by RegTheEvil
It's a work in progress and I will update this menu in time, and after I'm sure what items are completely unnesessary in my situation, I will remove them and only include the ones I really need and possibly add even more If I really have to but so far I'll let it stay the way it is. I know my menu is huge and possibly bloated but since it works and I can also boot into Windows from it - I can live with those things. Thanks for your feedback! Cheers! 😀
Comics made by me
