First post, by northdale
I have almost this card http://www.vgamuseum.info/index.php/news/item/348-s3-86c805
But it says p in front "p86c805" and no I at the end.
I have tried to install drivers for it (win 3.11) but non of the drivers seam to work. Windows restarts into dos saying could not start the driver.
I have tried a few drivers as you can see here.
28.86 KiB
youtube.com/uncleawesome
Reply 1 of 6, by blurks
What is the source of these drivers? Have you tried the files from metropoli BBS?
> http://files.mpoli.fi/hardware/DISPLAY/S3/
I'm not sure whether 805 and 805i chipsets share the same driver files ("i" = memory interleaving) but most likely yes.
Reply 2 of 6, by northdale
Hi. Yes I tried these drivers.
And drivers from here: VGA VLB S3 Digital Equipment Corporation (DEC) 86C801/805, basic info
and here http://www.retrocomputing.org/cgi-bin/sitewis … 200&id=retroorg
I just installed another vlb card that works, but I would prefer the other one.
Reply 3 of 6, by elianda
If the card has a jumper to enable INTerrupt, then make sure that it is set.
Youtube Channel
Reply 5 of 6, by northdale
I could not find such jumper to enable INTerrupt. I used another VLB to complete the video I was doing. But now I tried to install this VLB card again, because it's more period correct. It came with the machine. I think it is the Miro Crystal 8s. I get an error using the driver I found here: http://cd.textfil.es/cica/cica9603/disk2/disc … eo/00_index.htm
I couldn't figure out how to attach more then one file so I merged everything into one photo.
The card can't be broken? It seams to work fine except for that I can't install drivers.
