First post, by nemesisxiii
Has anyone gotten WC Armada to work multiplay, null modem, modem(virtual), or network?  If so, How?
I have .62 od DosBox and set it up so that it works and plays stably, however I was unable to get it to talk to another computer running dosbox and armada using many different methods.
Netplay seems to be out as when enabled there is an error saying that a network was detected and it cant load armada (this is mentioned in other threads). Is this something that might be corrected in the future (i.e. netbios support or someway to enable ipx drivers differently?)
I tried setting the com port to 1 and 2 under directserial and modem, and tried all the various speeds(within WCA) but it does not seem to work, it doesn't even seem to dial (no dial tone is heard or ?ring? message seen). It seems that from inside WCArmada the modem commands fail.
Is there an easy way to test to see if the virtual modem is functioning? Maybe it is broken or getting firewalled (though firewall is disabled).
Thank you in advance to whomever responds, one way or another.
If anyone is interested in troubleshooting or trying this remotely over the internet let me know.
