First post, by pete8475
I've been using Forceware version 175.19 but I've seen here and there online that some cards perform better with older drivers so I'm doing some testing today with version 71.89. Anyway here's some benchmark results:
Computer specs:
Intel Pentium 4 3.4ghz (Northwood)
Asus P4C800-E Deluxe
3gb DDR400 (2 x 1GB, 2x 512MB, dual channel)
Soundblaster Audigy 2 ZS
pics and additional computer details here - Pentium 4 System
175.19
Aquamark 3 - 38055
3dmark 2000 - 12723
3dmark 2001 - 14268
3dmark 2003 - 5156
3dmark 2005 - 1021
3dmark 2006 - 302
Quake 3 (1920x1080) - 224.3fps
93.71
Aquamark 3 - 37981
3dmark 2000 - 12894
3dmark 2001 - 14697
3dmark 2003 - 5278
3dmark 2005 - 1019
3dmark 2006 - 305
Quake 3 (1920x1080) - 228.1fps
71.89
Aquamark 3 - 38817
3dmark 2000 - 12688
3dmark 2001 - 15803
3dmark 2003 - 5265
3dmark 2005 - 1043
3dmark 2006 - crashes on second test
Quake 3 (1920x1080) - 231.9fps
56.64 - default clockspeeds
Aquamark 3 - 37397
3dmark 2000 - 13007
3dmark 2001 - 15299
3dmark 2003 - 5403
3dmark 2005 - 941
3dmark 2006 - 299
Quake 3 (1920x1080) - 233.5fps
56.64 - 500mhz Core, 800mhz Memory
Aquamark 3 - 45939
3dmark 2000 - 13310
3dmark 2001 - 17344
3dmark 2003 - 6374
3dmark 2005 - 1164
3dmark 2006 - 354
Quake 3 (1920x1080) - 260.5fps
45.23 (modified inf)
Aquamark 3 - 37731
3dmark 2000 - 12266
3dmark 2001 - 15983
3dmark 2003 - 4494 - Re-ran this a couple of times, it varies about 50-100 points up or down but the grass doesn't look "right" in the mother nature test with this version.
3dmark 2005 - 768 - There's some weird artifacts in the shadows in several of the tests with 45.23 I've attached a screenshot.
Quake 3 (1920x1080) - 229.7fps
All tests were done at stock clockspeeds (except where indicated), when overclocked to 500mhz core and 800mhz memory there's about a 15% improvement in most tests.
Performance does seem better in general with the older versions, at least up until the 56.64 drivers. The 45.23 version has weird artifacts in a couple versions of 3dmark. I got the 05 screenshot with printscreen and pasting into MSpaint, but printscreen doesn't seem to work with 2003 for some reason.
Are there any other versions I should test? I did not own any FX series cards when they were new and any time I did a build with one I just installed the latest and greatest drivers. Also are there any other benchmarks I should run?
    697.11 KiB
Reply 2 of 13, by pete8475
agent_x007 wrote:
93.71 please.
Also, you are quite CPU limited on 2000 and 01 SE tests.
Downloading now!
EDIT - Tests are done, results are in the first post. 3dmark06 runs fine now which is nice. I might stick with the 93.71 drivers long term.
EDIT 2 - HOMM2 looks nice and sharp still with these newer drivers, the only weird thing I've run into is the built-in "coolbits" overclocking keeps saying the 500mhz core and 800mhz memory isn't stable enough but of course Rivatuner still works so it's up and running at those speeds.
Reply 3 of 13, by swaaye
I would skip 3Dmark and test games you care about if possible.
Plus those drivers are way newer than the FX series. Differences will probably be almost margin of error unless you find a new game they actually cared to tweak/fix up for the old FX cards. 3DMark 06 would fit in that category I suppose. But to run that on a FX! yikes!
Reply 4 of 13, by pete8475
heh yeah I guess 3 years is a big difference, December 2003 for the FX5900XT and November 2006 for the 93.71 drivers.
As for testing games, well the games I'm playing on that machine are I76 and Heroes 2, not exactly benchmarkable. I have been playing Quake 3 on there too though and it runs very well.
I also installed Battlefield 1942 and the expansions last night and man that game is fun.
Reply 5 of 13, by swaaye
I'd give 45.23 a try. Unless you want to play DirectX 9 games on that card. The drivers after that were mostly about speed optimizations (read: image quality dropped) and desperation to be competitive in early DirectX 9 games before GeForce 6 was ready.
I mean you can run any drivers you like and neither HL2 dx9 mode or Oblivion are going to run acceptably on there for example. 🤣
I feel like the newest drivers are mostly for goofing around and experimenting, or running like Vista or Win7.
Reply 6 of 13, by pete8475
hah sounds good, I'll get 45.23 later tonight and post some numbers.
As for HL2 and Oblivion they run properly on Windows 10 and modern hardware, so I don't see any reason to install them here. I might put HL2 on here just to see how bad it runs though, heh.
Reply 7 of 13, by swaaye
Half Life 2 will run great as long as you run in the default DirectX 8.1 mode it uses for the FX series. It looks pretty good. I'm not sure what's entirely missing, but you will notice some blockyness in some effects.
Far Cry runs pretty well too. I think it uses a special FX rendering path with some DirectX 9 level effects.
Doom 3 might be the most impressive thing you can run well on them.
Reply 8 of 13, by SPBHM
if I remember correctly the water reflection is far nicer with DX9 in HL2,
Reply 9 of 13, by pete8475
Yeah all those run on current operating systems and hardware, no reason to install them on this machine.
I might try Interstate 82 on here, but I remember not liking the changes they made from 76 back when it was new.
Reply 11 of 13, by pete8475
So I downloaded that version and it doesn't support this model, the readme shows FX5800 and FX5800 Ultra as supported.
The oldest version that I can find that supports the 5900XT is 56.64, so I'm going to run some benches with that version. I'll add the results to the first post in this thread.
Reply 12 of 13, by BushLin
If you edit the .inf it'll run. The 45.23 driver supports the FX5900 and the FX5900XT uses the same NV35 chip.
extract the drivers, open nv4_disp.inf in notepad and add...
this line under [Manufacturer]
%NVIDIA_NV35.DEV_0332.1% = nv4_NV3x,                 PCI\VEN_10DE&DEV_0332
and this line under [Strings]
NVIDIA_NV35.DEV_0332.1 = "NVIDIA GeForce FX 5900XT"
Screw period correct; I wanted a faster system back then. I choose no dropped frames, super fast loading, fully compatible and quiet operation.
Reply 13 of 13, by pete8475
BushLin wrote:
If you edit the .inf it'll run. The 45.23 driver supports the FX5900 and the FX5900XT uses the same NV35 chip. extract the driv […]
Thank you! I will try that and post results in a little bit.
I think the first string of text actually goes in the [NVIDIA.Mfg] section, the [Manufacturer] section only has one line of text that says "%NVIDIA% = NVIDIA.Mfg" and the [NVIDIA.Mfg] is full of similar PCI\VEN stuff.
EDIT - Testing done, 56.64 seems to be a better choice for this card.
