Colours problem ISA Graphics
First post, by Almoststew1990
I only seem to notice it in Secret of Monkey Island
I walk into the SCUMM bar and I get this:
From a youtube playthrough, it is meant to look like this.
Pirate Dude on my PC:
Pirate Dude on normal PC:
I've tried reseating the card many times. Rarely, it will fix it. Same for a trying it in a different slot. I might have to reseat it 5 times for the colours to come out correctly but if I then leave it alone and seated, it will be fine until I disassemble the PC. Is it my motherboard, or the card? Do I need a new card? That be a shame as it is reasonable card for ISA. Here is the card (can't remember the model at all but you guys recommended it) :
I can get a basic ISA VGA card for £15 (this is only for a slow-ass cacheless 386SX) so I might give that a go regardless. Should I get a Trident 8900C or 9000B for £10? They're both pretty "average to meh" (ftp://retronn.de/docs/eliandas_isa_vga_roundup.pdf)
Reply 1 of 21, by SSTV2
It looks like video DAC related issue. I'd try to boot PC into clean DOS (all drivers/programs disabled) to rule out software related issues 1st.
Reply 2 of 21, by retardware
Looks like palette access error.
Such glitches are typical of bad buffering.
I am quite sure the cause is the old tantalum caps.
I'd suggest to replace the tantalums on your Acumos (acceptable) board instead of buying a Trident (bad) card.
Edit:
Look carefully at the picture of your card, see the vertical stripe pattern. Such is surefire indicator of bad caps.
Reply 3 of 21, by Almoststew1990
retardware wrote:
Looks like palette access error. Such glitches are typical of bad buffering. I am quite sure the cause is the old tantalum caps. […]
Edit:
Do you mean on-screen? I had wondered about that. I don't have a soldering iron or any experience. I might get a slow trident whilst I move house and then I can think about learning to solder. I have a PCI ET6000 for my fast DOS PC anyway.
SSTV2 wrote:
It looks like video DAC related issue . I'd try to boot PC into clean DOS (all drivers/programs disabled) to rule out software related issues 1st.
It is already in pure DOS, I just did a fresh install. Not even sound drivers installed at this point!
Reply 4 of 21, by Jo22
Hi, please tell what computer you are using - If it is a 486 or 586, there's a chance enabling/disabling "Video Palette Snooping" in CMOS Setup couldl fix this issue.
Reply 5 of 21, by root42
I think this only applied to PCI video cards. However toggling the setting is certainly worth a try.
Could this be caused by messed up color settings on the monitor perhaps? Have you tried a different screen or the color settings of the screen?
YouTube and Bonus
Reply 6 of 21, by Almoststew1990
I've used the screen for a variety of uses this week (Windows 7 PC, second monitor on laptop, Dreamcast) and it's been fine with everything else. All the other colours look OK too, it's just "reds".
It's a.... this:
386SX 40MHz. 4MB of RAM, using a CF card for storge and Gotek floppy emulator. I was using a CT3910 AWE32 (it's my only soundcard with real OPL sound).
I can either get a slow Trident for £10 (again... this is on a 386SX that can barely play Wolfenstein 3D with a good graphics card 😜) or coincedently another Acumos AVGA 2 for £35. I kind of don't want the same card twice thought, that's boring!
Reply 7 of 21, by root42
Only the reds you say? Maybe one of the components in front of the VGA out is broken. Like retardware siad: tantalum caps. Or the ceramics or diodes maybe? Perhaps you can test them.
YouTube and Bonus
Reply 8 of 21, by Thermalwrong
Check the back of the card for any pins that might be touching, I had a similar problem with a Western Digital ISA VGA card from around the same time period - some of the pins on the back were touching because they weren't cut as short as on more modern cards, bending them back to being straight fixed it.
Reply 9 of 21, by Caluser2000
Having an ISA Trident as a back up/fault finding card is a good idea I've found. At least you have a complete working system that way while repairs are being done.
Reply 10 of 21, by Jo22
I second that. The Trident 8900D was a good card, actually. It had FiFos (?) like the ET4000 and could change to CGA/EGA and Hercules modes via mode utility.
And it was very widespread (!=popular) and reasonable compatible. That's one of the reasons DOSemu had choosen that Trident line for its VGA core, I believe.
"The emulator emulates a basic Trident TVGA8900C graphics card. All standard VGA modes are emulated, most VGA hardware features (mode-X, 320x240 and so on),
some Trident extensions, and on top of that many high-resolution VESA 2.0 modes, that were not present in the original Trident card. Some (very few) programs,
such as Fast Tracker, play intimately with the VGA hardware and may not work. As vgaemu improves these problems should disappear
Source: http://www.dosemu.org/docs/README/1.4/x553.html
If it comes to old adventure games, like these AGI/SCI0 games from Sierra, an ISA card is handy.
Some animations aren't working properly on PCI cards, providing a wrong atmosphere to the game.
There was a discussion about this years ago here on Vogons.
I'm sorry, can't remember the thread name of it anymore. 😢
Reply 11 of 21, by Caluser2000
Found this thread wrt Cirrus GD5429 vs T8600D cards Cirrus Logic CL-GD5429 vs Trident 8900D - disappointing
Reply 12 of 21, by TheMobRules
retardware wrote:
Edit:
Interesting, I have an AVGA2 card which is very similar to the one the OP has, but mine has a green PCB and says "Made in the USA". The colors are good, but it displays the same vertical bands issue as shown in the screenshot posted. It happens on both LCDs and CRTs, altough it is more noticeable on LCDs.
I always thought it was just a poor quality DAC or something like that. Do you think it may be fixed by replacing the tantalums on the card?
Reply 13 of 21, by keropi
many old vga cards heve those strips, it's not the caps but their DACs and surrounding circuits... 99% of times they are fine on CRT screens so it's just the way they were made back then...
Reply 14 of 21, by Almoststew1990
Bumping my old thread because I did get a new AVGA 2 card... and it has the same issue! Do you think I am just unlucky, or maybe it's a weakpoint on these cards? or does this now point to the motherboard?
Reply 15 of 21, by The Serpent Rider
Apparently Acumos AVGA2/Cirrus Logic 5402 aren't very stable cards to begin with, because they had to rely on motherboard oscillator, which can cause problems. I think underclocking your system to 33 or 25 Mhz could help.
Reply 16 of 21, by Uka
I have bought a very similar Acumos AVGA2 videocard today:
The attachment Acumos.jpg is no longer available
However, for me the 'Monkey Island' palette is displayed correctly:
The attachment MI1_Acumos1.png is no longer available
The attachment MI1_Acumos2.png is no longer available
So that should have been some motherboard falut. Or maybe even a broken version of the game?
Reply 17 of 21, by Almoststew1990
Thread bumpity time.
The card started giving me the same issues again.
I bought a Trident 9000C to see if it did the same thing. Weirdly, it did!
I went into the BIOS and turned on Video memory shadow something something. Didn't help.
I tried "another version" of the game. It now works perfectly.
On the one hand, FML! On the other hand, yay, now I can play Secret of Monkey Island!
Reply 19 of 21, by kolderman
Lol
