First post, by kalm_traveler
So now that I have the rig built mostly, and things are starting to be stable and set up, I decided to figure out why the rear IO USB ports don't work.
I've tried several keyboards and mice, as well as flash drives but nothing seems to work.
Thinking about this, I recalled how pre-3.0 USB only had 4 wires, +5v, GND, and 2 data wires. A quick search reminded me that the two outside pins in an A connector are the +5 and GND pins.
Pulling out my trusty multimeter, I measured the voltage on both of those ports power pins and am a bit surprised by the results... the lower port (closer to the PCB) is ~ 2.05v , and the higher port (farther away from the PCB) is ~ 1.99v
Now... call me crazy, but 2 volts is a lot less than 5 volts. This explains why nothing plugged into those ports is working, but now the question is why would the voltage be so low?
Another interesting quirk is that the USB header on the board works just fine - I connected one of those slot expansion brackets and tested several devices going through the header and it is just fine so there's nothing wrong with the USB controller itself - just something funny going on with those ports on the rear IO...
Any suggestions on what I should look at next to hopefully fix them?
Retro: Win2k/98SE - P3 1.13ghz, 512mb PC133 SDRAM, Quadro4 980XGL, Aureal Vortex 2
modern:i9 10980XE, 64gb DDR4, 2x Titan RTX | i9 9900KS, 32gb DDR4, RTX 2080 Ti | '19 Razer Blade Pro
Reply 1 of 21, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
I remember owning a CUSL-C (or similar - I don't remember exactly) with flaky rear ports but working fine interior port.
Maybe it's just a flaw
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 21, by kalm_traveler
ooh that's good to know, thank you.
I'm going to try replacing the socket with a brand new one and see if that helps. The housing looks pretty oxidized so it wouldn't surprise me if the pins internally are just decayed to the point of not conducting well enough to work properly. Will update once I have soldered the new one on with the results!
Reply 3 of 21, by Thermalwrong
Try setting the USBPWR01 jumper to 1-2 instead of 2-3 if it's on that, the manual warns that a weak 5v Standby rail (less than 2a) could cause problems with the USB. It's not like there's a voltage regulator for USB, but your PC is working, the first thing I thought was maybe a bad PSU? But I think you'd notice if 5 volts isn't working properly. Maybe a bad 5v standby rail could cause this problem?
Reply 4 of 21, by kalm_traveler
I'll try that jumper. Those 2 ports have been non-working the entire time with all PSU's tested though (currently using a brand new Corsair HX1200). I haven't tried enabling USBPWR on either those rear I/O ports or the header, but as I mentioned the header works just fine already.
Reply 5 of 21, by Bige4u
My apolagies, for im not much help for an answer to the low voltage situation... but i've used that same motherboard in the past along with WIN98 installed and just added a 4port usb2.0 PCI card, so perhaps forget about using all the onboard usb ports.
Just go with a usb2.0 PCI card, works perfect and much more reliable IMO, unless you're really handy with the desoldering iron, dont risk it, you might damage the rest of the motherboard by accident leaving it inoperable, those motherboards are getting a little harder to find nowadays and expensive.
Good Luck
Pentium3 1400s/ Asus Tusl2-c / Kingston 512mb pc133 cl2 / WD 20gb 7200rpm / GeForce3 Ti-500 64mb / Sound Blaster Live! 5.1 SB0100 / 16x dvdrom / 3.5 Floppy / Enermax 420w / Win98se
Reply 6 of 21, by Intel486dx33
What OS are you using?
If you are using Win95 or 98 you need to install the USB update patch.
I think it’s called “nUSB”.
Here are some USB pin-out connection diagrams.
I use an USB extension cable from the motherboard to the front USB connections if your cables are too short.
Make sure you don’t get your wires crossed,
Separate the USB port-1 wires from the USB port-2 wires.
Pins 9 and 10 are nothing ( dead ). Not needed.
Wires color code:
White - data -
Green - data +
RED - 5v, Vcc
Black - ground
Reply 7 of 21, by kalm_traveler
Good Luck
Thank you! - I do actually already have a usb 2.0 card installed, but that doesn't help until Windows loads (IE had to dig out a PS2-compatible keyboard and USB to PS2 adapter to get things set up since the rear USB ports are not working). Now that I know the internal header still works I could use those with a rear panel expansion bracket but I'd like to get this thing 100% functional.
Soldering parts this large is not much worry for me, and I have desoldering braid, flux, quality leaded solder etc so it should only take me 5-10 minutes to replace the socket once it arrives.
Reply 8 of 21, by kalm_traveler
Intel486dx33 wrote:
What OS are you using? If you are using Win95 or 98 you need to install the USB update patch. I think it’s called “nUSB”. […]
Wires color code:
White - data -
Green - data +
RED - 5v, Vcc
Black - ground
Hi there - I am running Windows 2000 at the moment, planning on adding a dual boot option for either Windows Me or 98SE next weekend. As I mentioned in the OP, the 2 ports from the motherboard internal header work just fine, and this is definitely a hardware problem specific to only the 2 ports on the rear I/O part of the motherboard.
As you reiterated, USB ports should have +5v and GND for power, and 2 data pins, but when measuring those 2 non-working ports on my board they are both only reading approximately +2v (the lower one is just above 2 volts and the higher one is just below 2 volts) so something is definitely skewompus with them.
I bought a new socket to replace that original one for about five dollars, and am very capable of replacing it in 5-10 minutes so hopefully that will do the trick. Given that the motherboard header USB ports still work properly my guess is that the metal of this original socket has just corroded internally so it isn't making good connection with the PCB anymore.
Reply 9 of 21, by kalm_traveler
decided to prepare for the new port since I had a few minutes tonight - removing the old one was more work than I'd expected but it's out and I didn't melt anything so that's a win 😀
749.37 KiB
no more USB ports
Reply 11 of 21, by kalm_traveler
photomaster wrote on 2019-09-11, 22:37:
@kalm_traveler
Hey man, have you managed those USB ports to work?
whoops, I forgot to reply - no sadly the connector was not the issue.
In fact, I picked up another TUSL2-C and it has the exact same problem. The 2 rear USB ports don't seem to work at all ever, but the 2 onboard header USB ports work just fine.
Reply 12 of 21, by quicknick
Volts don't just disappear, you have somewhere a big voltage drop, just follow the path. Can't 100% tell from the picture, but seems there's a (poly)fuse and perhaps an inductor (L20) and a jumper to choose between +5V/+5Vsb to be checked. I have encountered a bad inductor near the KB connector on a Abit KT7, resistance went up to tens of ohms and the keyboard was only receiving around 3 volts and operation was flaky. Replaced that, solved the problem. Good luck!
Reply 13 of 21, by pentiumspeed
The resettable fuse is bad on these. Green medium size SMD package near these USB connectors. Turn off and no power, measure across these with meter set to ohms. Should be under 0.1 ohms.
Another way to get 5V routed through is using powered USB hub.
Cheers,
Great Northern aka Canada.
Reply 14 of 21, by kalm_traveler
quicknick wrote on 2020-09-28, 21:27:
aha!
Well you piqued my interest here.
On the original board, with power on there is +4.98v on pin 3 of the USB standby power jumper area, but on all the small components nearby only about 2.4v
If I move that jumper from 1-2 (enable) to 2-3 (disable), the port sort of works for a moment upon bootup and I can get into BIOS with a USB keyboard, but then the ports stop working as soon as BIOS screen loads.
WIth the new board, moving that jumper just makes the USB ports work. Can get into BIOS and make settings etc.
Curious, why would enabling USB wakeup (I'm assuming that means +5v standby is fed to the ports?) make the ports just stop working but disabling it works fine?
Reply 15 of 21, by kalm_traveler
pentiumspeed wrote on 2020-09-28, 23:27:
Cheers,
I'm not sure I see the component you're mentioning - is it in that picture? I can try to take another picture now if that would help pinpoint it.
Odd that with both of these TUSL2-C boards, the USB header works fine but he rear ports were angry.
Reply 17 of 21, by kalm_traveler
Doornkaat wrote on 2020-09-29, 02:30:
I'm also suspecting the fuse. It's most likely the
larger rectangular green flat part that reads 'P 160' on it. It is marked as F3 on the PCB silkscreen.
I checked that one on both motherboards (for continuity only) and they both show continuity.
What's interesting to me right now is why they only read about 2.5v when +5vsb is enabled (and as I mentioned, that 3rd pin on the disabled/enabled jumper reads 4.98v to ground).
Reply 19 of 21, by texterted
I suppose you could just bridge the suspect components and check the voltages at the ports. Be careful tho. be a shame to brick the board for a small slip!
Cheers
Ted
98se/W2K :- Asus A8v Dlx. A-64 3500+, 512 mb ddr, Radeon 9800 Pro, SB Live.
XP Pro:- Asus P5 Q SE Plus, C2D E8400, 4 Gig DDR2, Radeon HD4870, SB Audigy 2ZS.
