First post, by Jager
Or should I call this none-on-one, since it's several kits intended for a single test bench rig and none of them are 100% complete? 😒
10 years ago or so I've collected some old hardware, and now I'm testing if it actually works. And, indeed, most of it works perfectly, with one pretty sad exception - CT3990 with a dead EMU8000. Now I'm planning to add missing components so I'll have several CPU-MB-RAM-Video kits for different PC gaming eras. Currently I have:
XT:
NEC V30 10MHz on a Juko Nest N3 with a 640K RAM and 8-bit Tseng ET3000. A full 1MB can be soldered, but I'm not really sure if I need EMS here. Currently missing I/O (the easiest part), FDD controller (1.44 is rare, might use 720K instead), fixed storage+controller (XT-IDE or DiskOnChip), sound (Adlib replica) and keyboard (or XT-AT converter). As far as I understood I can use 16-bit I/O with XT IDE BIOS and a CF card, but that's "plan B".
286:
Actually I've got two 12MHz boards, but they fit badly in my lineup, so I'm searching for a 20 or 25 MHz Harris board with a decent chipset. 2-5 MB RAM, OTI037 as a placeholder for a VGA.
386:
AMD 386DX 33@40Mhz on a M321 with 8MB RAM and 64k cache. 4MB SIMM30 modules are rarer and pricey, not sure if I want 16MB. Cirrus Logic 5402 512k as a placeholder for a VGA. 5402 is nice & low-profile, but it has shaky image (probably needs recap?) and it will be probably better choice for a 286 kit.
486 DOS/Win3.1:
AMD 486DX4 120MHz on a Olivetti MODULO M4-4*4 motherboard. 32MB RAM, 256k cache, integrated Cirrus Logic 5428 and EIDE - just needs a sound card. Bit slower than expected due to high memory/cache timings with no way to alter them - no chipset options in BIOS and AMISETUP doesn't work. On the plus side this MB is working with EDO RAM.
From now on things get trickier.
Socket7 P1 Win95:
I've got 2 MBs - FIC PT-2007 and Lucky Star 5vp3, and I'm not sure which one to choose. PT-2007 is a nice 430tx-based board, but it needs recap and RAM is bit of a problem. Since I want full 64MB - 5V DIMM or 2 more 16MB SIMMs needed. 5vp3, on the other hand, can provide 3V to DIMMs, has ATX power and AGP port, but might be bit slower. Placeholder CPU - 166MMX, will be replaced with a 233MMX. For video - S3 card, depending on MB, plus I'm searching for a Voodoo1.
Slot1 Win98:
P3 Katmai 600 MHz on a Chaintech 6BTA3 MB with 512MB RAM. GF2MX as a placeholder video, probably I'll buy Voodoo3 later on.
S370 Late Win98:
Recently I've bought a 1.1GHz SL5QW P3 for 2$ and I was planning to use it with a slot1 adapter, but now I think 133MHz bus P3 + 815ep might be a better choice. Same 512mb RAM as before, since it's Win98 kit. Searching for a Gf4Ti and Radeon 8500 for video.
For ISA sound I've got working SB16 CT2980 and AWE64 CT4500 in unknown condition been shipped. Looking for a decent versions of a YMF71x, ESS and ALS100.
For PCI sound I've got Live! 5.1, looking for a Vortex2.
I'll probably skip Socket 4&5 P1 and P2. Any advices on these builds?
Reply 1 of 5, by Caluser2000
V30 For 3.25' drives just use a generic Winbond or similar multi i/o card with floppy drive support and fit 1.44drive. It will boot as 720k but using a small tsr called 2M you can access a 1.44meg disk. Also you get the added bonus of ltp, com and possibly a games port. If you look a Anonymous Cowards XT'ger page there's some other things you can do https://sites.google.com/site/misterzeropageh … misterzeropage/ Monotech https://monotech.fwscart.com/category/cards has some nice 8-bit cards as well as keyboard converter. They're listed on e-bay but it's a bit cheaper contacting them directly.
286 I agree 20-25mhz Harris cpu would be cool. 286/12s can be quite capable though. I run Windows 3.1 on my Zenith Z286LP Plus which has some nice features generic 286/12s don't have, like supporting 8megs of ram out of the box. The OAK vga card will be just fine.
386 sounds good so far.
486 sounds good also.
Socket 7 will come down to trial and error to which mobo you select but using the known good board is a good start. If you get the other recapped it should be easy enough to do out of the case testing mixing and matching until you find the combination you like.
Wont comment on the others as they really aren't on my radar preferring Supper Socket 7 solutions.
Best thing is though I guess is to concentrate on a few systems at a time say the most complete then progress.
Reply 2 of 5, by PARKE
That is a pretty uncommon cpu (there is currently one for sale on Ebay for +60 dollars). It is the fastest fsb 100 Coppermine and deserves its own 440BX s370 mobo for the best result.
Reply 3 of 5, by Jager
That's also plan "B", I'll try to use only 8-bit cards in my V30. And, to my knowledge, 1.44M 8-bit controllers basically use the same trick - just with a ROM extension instead of tsr. Since I have Gotek with Flash Floppy its not a big deal though, 720k should be enough. BTW my Juko board is alive thanks to Anonymous Coward.
I know, and that's one of the reasons why I want to switch to Tualatin P3-S + 815 instead. The second reason is much higher performance in games with a 133 fsb (plus higher clocks and bigger cache on tualatins).
Reply 4 of 5, by zyga64
Quite unusual. I would say it needs "low density" 16 MBit SDRAMs (vs more popular 64 MBit), but not 5V (for SDRAMs). 3.3V ones should work just fine.
Edit1. No, I was wrong. It accepts 64MBit DIMMs. According to this table: http://www.pchardwarelinks.com/chipsets_pentium.htm
Edit2. From board manual: "DIM1 and DIM2 only support 3.3V (unbuffered) EDO and SDRAM modules."
8088@8 /640k /Genoa CGA /TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 5 of 5, by Jager
Not sure how this supposed to work, since there is no voltage converter near RAM slots and I measured 5V over empty slot. Probably SDRAM should be 5V-tolerant, I've read about such modules, but mine are 3.3V-only. 😕
Add:
5vp3 with SDRAM ended been slower than PT-2007 with EDO. What a shame. 😒
Add2:
This board actually had a faulty 3.3V regulator, feeding 5V to ALL components instead of 3.3V. One more phobia for me. 😵
