First post, by user33331
Hello
Searching for a laptop cd and\or dvd drive which is 9.5mm thick and has a standard JAE-50(="Slim IDE") connector.
- Usually they are 12.7mm thick.
- Thinkpads'=T60,T61..."Ultrabay Slim"-drives like UJ-862 are no good because yes it is 9.5mm thick but it has a custom security connector which is not JAE-50 but similar.
Apple Macbook has one but it is slot-load and no bezel:
- UJ-857, UJ-867.
These are maybe: ( Got to look more...)
- UJ-842.
- GSA-4083N.
Also laptop's model might be more important than drive's code when searching.
- If anyone has a huge lot of laptop optical drives around to check.
Reply 1 of 5, by PC Hoarder Patrol
Maybe do a web / eBay search for 'DVDRWTRAYIDE95' (OSST-branded?)
Reply 2 of 5, by user33331
Is there a logic behind these model numbers: ?
Searched whole day these seem plausible ?
UJ-832
UJ-842
UJ-852
UJ-857
GSA-4083N
GSA-U10N
GDR-8087
Wish there would be a easy list. 😊
Reply 3 of 5, by Thermalwrong
I think you've listed them all pretty well there.
I have a couple, you want to look at early PCIe era laptops. The Sony Vaio SZ series all had them, I think the UJ-852, but they had quite a non-standard bezel.
I removed one from an unrepairable vaio TX laptop the other day. That's also 9.5mm height, tray load with a bezel, but it's very thin and has no top cover / frame. That's the UJ 822.
The GSA-U10N is a good choice, the thin HP laptops from back then had them and I've got one here with a fairly standard bezel on it. That should be the HP Compaq 2510p
Reply 4 of 5, by Warlord
thats just a normal laptop IDE connector.
Reply 5 of 5, by user33331
I came to a conclusion these 9.5mm JAE-50(IDE) are used in laptops manufactured only around 2005-2008.
Pre -2005 is 12.7mm IDE and after around 2008+ is 9.5mm SATA.
HP Multibay II +Detachable adapter
- NC2400 NC6000 NC6100 NC6120 NC6220 NC6230 NC6310 NC6320 NC6400 NC6910P NC8200 NC8230.
- NX6130 NX7400 NX8200.
- NW8200 NX8220 NW8240 NW8440 N​W9440.
- 2510p, 2710p, 6910p, 2230S.
- Apple Powerbook G4
- Dell XPS M1330
- Sony Vaio SZ (2006-)
