First post, by Jo22
Hi everyone,
I'm looking for a Sound Blaster 16 driver,
more precisely a third-party 16-Bit driver for PC/GEOS 3, 4 aka New Deal Office, Breadbox Ensemble etc.
Does anybody know if such a thing exists ?
In Breadbox Ensemble, there are built-in Sound Blaster 1.x drivers that do work,
but they can only do 8-Bit resolution. That's not enough, sadly.
Any help appreciated! 😀
Ediit: Sorry, wrong sub forum, I guess. 🙁
Reply 1 of 17, by Jo22
No idea ? Please share the information that you have, may it only a bit.
- I need an answer until tomorrow for a little project.
It's not critical by any means, but I'd really like to finish it in time.
Reply 2 of 17, by root42
Well, I only know GEOS and GeoWorks from magazine ads. Sorry. Any workaround possible? Downsampling the files in question?
YouTube and Bonus
Reply 3 of 17, by Jo22
Thank you for your reply! Yes, I tried downsampling, but the result was not clean enough for my Morse decoder. 🙁
(- I tried to use Breadbox Ensemble as a Wave player for may SAQ recording, see Next SAQ transmission planned soon )
Reply 4 of 17, by derSammler
Check what other drivers are built-in. If any of those are for a 16-bit sound card, replace the sound card with that model.
Breadbox Ensemble was meant for office work and it's highly unlikely that they cared about adding support for the SB16 if that card did work with the drivers already built-in.
Reply 5 of 17, by Jo22
Thanks for your replay, too!
This is what I can choose from. The software is from the 2000s..
Reply 6 of 17, by root42
My bet is that they have only one driver, which takes care of the slightly different DSP commands and/or sampling rates. Is there a homebrew community for geoworks, which might have made third party drivers?
YouTube and Bonus
Reply 7 of 17, by derSammler
Maybe you could try the last version of Breadbox Ensemble released. Your screenshot certainly isn't from the last version. No idea if it had more sound cards to choose from, however.
Another idea might be using an ESS-based sound card with the SB driver. Those have much better noise levels.
Reply 9 of 17, by Jo22
Thanks! If I had a few weeks left to tinker, I surely would have a look at it.
Unfortunately, the weekend is almost over and I wanted to finish the SAQ video a week after the original event happened.
I could have used any WAV/PCM player to feed the Telereader, but I thought I should give Geoworks/Ensemble a chance.
Hi, what's the current release please ? My kernal seems to be 4.1.0.1.
Reply 10 of 17, by derSammler
I'm not fully sure, but there certainly was a 4.2 release. I have to check what versions I have in my collection.
Reply 11 of 17, by Jo22
Thanks! 😀
Reply 12 of 17, by derSammler
I have 4.1.2 from 2006, which has no Sb16 driver either. GeoWorks at some point however seems to have had a dedicated Sb16 driver. So going for an older version might be the solution.
Reply 13 of 17, by leileilol
Somehow I doubt PC/GEOS ever had one. They're practically hardware support frozen since 1991 and always were the odd duck for forever sticking to that in the 2000's commercial OS market...
Reply 14 of 17, by Caluser2000
I can't recall any. My first version was 1.2 Pro and ran NDO 3.2a for a bit. Just checked out Breadbox Ensemble 4.1.2 and it has the same drivers as NDO. It really wasn't a multi media GUI. More a compliment to Dos really. Things like 256 plus colour wasn't really a priority. With it's release under GPL there may be a grass roots/hobbiest interest in it to add features. Still a few copyright issues to sort out iirc.The SDK had been available tor quite some time.
Reply 15 of 17, by Caluser2000
It could be if it is running the Motif interface. The shaded bar at the top of the windows indicate it's a later version.
Reply 16 of 17, by Jo22
Thanks everyone so far! I'm still learning about PC/GEOS and I'm fine with its hardware support otherwise.
It's just that the 8-Bit resolution wasn't producing the kind of signal needed for that special device (Telereader CD 660)..
(I tried both an original SB 2.0 and SB16 as well as emulated versions of these in PCem. Perhaps I should use an ISA/PCI card with SB emulation, too - it might smooth out the signal.)
Yes, that's the case. I changed it back to Motif, since it seemed friendlier to me. In some way or another, it looked a bit like TWM window manager of *nix, also, which I like.
Reply 17 of 17, by Caluser2000
Kidguard in Preferences is a clue to. Yeah I prefer the Motif interface as well. The so called Industry standard interface is just blah and boring.
