First post, by kalm_traveler
Just wondering if this might be a good idea for my main retro rig. Most of the older games I want to play on it either are already native Windows or are newer DOS titles and seem to still work correctly under Windows 2000 but there are a handful that seem to need actual DOS (or at least DOS overlayed by say Windows 9x) to run correctly.
Rather than hassle with dual-booting 9x and 2k on this thing, might it make more sense to just play those few games on it via dosbox? Or would it be too slow to emulate a 386/486?
Retro: Win2k/98SE - P3 1.13ghz, 512mb PC133 SDRAM, Quadro4 980XGL, Aureal Vortex 2
modern:iRyzen 9 9950X3D, 64gb DDR5-6000, RTX 4090 FE | 2019 Razer Blade Pro
Reply 1 of 3, by luckybob
It will work okay.
A dual p3 1.4 is best suited for early XP games.
but building a "retro" pc to play slower games is a bit of a head scratcher for me. Might as well do it on a new machine and save the time/effort.
Reply 2 of 3, by DosFreak
DOSBox works on Windows 2000 but it'll only use one core so don't expect many protected mode games to run well on a P3. Install VDMSound and NOLFB for those or dual-boot with DOS.
Make your games work offline
Reply 3 of 3, by kalm_traveler
luckybob wrote:
It will work okay.
I had a 'best of 2000' rig but the motherboard had some issues so I decided to upgrade it. There are a few old games that I play which run too fast on modern machines so i figured it would be fun to build a retro rig and run everything on original hardware, plus that you can drop the cpu multiplier to get speed-sensitive games to run properly.
Anywho thanks both of you! I'll give it a whirl, and if worse comes to worse will set up dual boot
