First post, by croton64
Hi,
i've found an Acer PZ25D, came with a 486sx/25 and it's mostly complete and good overall shape, cleaned up and reassembled it.
As soon as i've pushed the start button, monitor came on...but i hear no sound, not even a beep, nor the PSU fan (will check this), i've pushed it off ASAP so wasn't able to read BIOS string on the screen
I've checked online for manual or jumper settings for the motherboard, it seems to be a V6 mobo... but i've found only a diagram about it and it seems to be at least three versions.
If anyone has or had such a system and could upload the manual or could point me in the right search path to find it, i'll be grateful.
The attachment mobo.jpg is no longer available
The attachment biosV.jpg is no longer available
It also came with this board, seems to be an ethernet adapter, but besides utp and coaxial connectors, it also has something akin to a game port.. so it should be some kind of capture device i think. Wish to look the driver but i can't identify the thing
The attachment card.jpg is no longer available
Regards
Reply 1 of 9, by dr.sbaitso
The 'game port' on your network card is probably an AUI connector used for 10BASE5 ethernet. Seems based on a natsemi/ti 8390 chipset, which was common as muck on ne2k clone cards.
Reply 2 of 9, by chinny22
486's under 66 Mhz are pretty tough, You can leave it on longer if that's what your worried about.
Good thing about AT Power supplies is that you can use them even if disconnected from everything. I would expect the fan to work in that as soon as it had power, but event then wouldn't think it would get hot enough in the first few seconds to check bios for any info
Reply 3 of 9, by flakes
I know this is an old post but...
I have one of these motherboards given to me and i decided to test my wash technique on it. It still works but i dont have the pinout for the White Keyboard connector or FP LED that are just below the L2 cache sockets. Can Anyone help! Also the setup utility would be of help when i get a keyboard hooked up!
The attachment ACER.jpg is no longer available
Of interest its got 4MB on board Ram and 256KB Cache...
The attachment ACER2.jpg is no longer available
Reply 4 of 9, by croton64
Thanks for the info, never knew that conector existed.
I've changed the fan and seems to be working good, with no load it starts but makes coil whine.. so maybe i've to check it better, although voltages seems fine.
Anyway, once connected it starts ok.. but it shows no much more info than BIOS version
The attachment 20190716_205303_24408.jpg is no longer available
It seems you have a newer revision than mine, better VideoCard and full video memory as well.
Do not have the proper pinout for FP.. but these images can help you with the wiring.
The attachment 20190827_213204.jpg is no longer available
The attachment 20190827_213231.jpg is no longer available
LightBlue wire is behind orange one.
Keyboard connector otoh (last image on the right), goes directly into a board with a pair of PS2 females on it, i could take a picture if you wish..but don't know how useful may it be.
Regards
Reply 5 of 9, by flakes
Hi croton64
Thanks for the Photos. is there any chance you can take a photo of the connectors on the other end of the Black Keyboard Lead, It will help me work the Pin-out for that connector.
I managed to get mine to boot past that initial screen shown by having a working Floppy drive attached, But it asked me for a system disk and wouldn't take the MS-DOS boot Floppy. I will see how i go when i get a Keyboard hooked up.
As for your fan, I wouldn't worry too much at this stage. Mine is a DX33 without a fan and does not need it.
Reply 6 of 9, by croton64
flakes wrote:
Hi croton64
The attachment 20190831_164209.jpg is no longer available
The attachment 20190831_164225.jpg is no longer available
Mine reads no input from keyboard so can't enter SETUP, need to check the ports and more info about jumper settings.. it keeps saying video card mismatch... but it's a soldered CL5422, there was no other video card.
PSU fan was dead, wouldn't risk to blow it... as i can use it on other machine.
Regards
Reply 7 of 9, by flakes
Thanks for that.
I have now got the pinout and will work on the board this weekend.
For interest i have worked it to be:
1. Green - +5v (Ps2 Pin 4)
2. N/C
3. Red - Clock 1 (Ps2 Pin 5)
4. Grey - Data 1 (Ps2 Pin 1)
5. Black - Shield for Caps on Data Lines
6. Yellow - Ground (Ps2 Pin 3)
7. Brown - Clock 2 (Ps2 Pin 5)
8. Blue - Data 2 (Ps2 Pin 1)
It will matter what PS2 Port is used for Key and Mouse. If it dosnt work in 1 then try the other!
Of cause this data is for the PS2 end of the cable not the motherboard!
Reply 8 of 9, by croton64
It's labeled on the case, there's no way to miss it (besides mini-board doesn't fit the other way)... anyway i've tested two keyboards with similar results... maybe the board or cables have some issues.
Will test cables first and then connectors according to the pinout you provided.
Thanks!
