First post, by chrisNova777
does anyone know if there is a product to adapt a new power supply to connect to an older motherboard with the older P8/P9 power connectors (see attached photo::) ive received complaints that my windows 95 computer is too loud 🤣
oops i guess i just had to figure out that they were called p8/p9 connectors and then google to find my answer
https://www.computerhope.com/jargon/p/p8.htm
https://www.ebay.com/itm/Internal-Power-Adapt … zgAAOSwXOVabHRf
https://www.ebay.com/itm/ATX-20-pin-to-AT-P8- … 9-/270818956893
https://www.amazon.com/20-Pin-Power-Supply-Ad … e/dp/B01EDGS0KI
https://www.amazon.com/20-pin-3-Pin-Power-Swi … 9/dp/B016S7OGVW
http://www.oldschooldaw.com | vintage PC/MAC MIDI/DAW | Asus mobo archive | Sound Modules | Vintage MIDI Interfaces
AM386DX40 | Asus VL/I-486SV2GX4 (486DX2-80) | GA586VX (p75) + r7000PCI | ABIT Be6 (pII-233) matroxG400 AGP
Reply 1 of 2, by canthearu
They all work fine. I got a couple with the spade connectors (I just jimmy the spade connectors together to get the ATX PSU to start when I turn the back switch on)
Reply 2 of 2, by cyclone3d
If you need the -5v (really only for some specific sound cards), make sure to get one with -5v added.
The dummy load may also be needed for newer power supplies to regulate the voltage properly.
Look for seller Antronst on eBay. (not me)
https://www.ebay.com/itm/ATX-EPS-24-PIN-to-AT … SA/254124137678
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
