First post, by Intel486dx33
Hi, I need a good basic CDROM driver or install diskette for IDE Teac 4x cdrom drive.
A universal IDE driver with install.bat file would be nice.
Reply 4 of 11, by Jo22
There indeed used to be diskettes like this..
They were included with some CD-ROM drives (bulk), if memory serves.
I've attached one for you. Good luck!
Hope it doesn't interfere with forum rules (it's just the plain installer+driver).
    atapi_cdrom_install_floppy_dos.zip
    51.07 KiB
    59 downloads
    "High-Speed CD-ROM Drive" driver floppy (DOS)
Reply 5 of 11, by BushLin
The Toshiba CDROMDRV.SYS is light on RAM usage with decent compatibility. Another good choice is OAKCDROM.SYS for higher RAM usage with apparently better compatibility. Not had any problems with the Toshiba one myself.
https://www.legroom.net/howto/msdos#device
Screw period correct; I wanted a faster system back then. I choose no dropped frames, super fast loading, fully compatible and quiet operation.
Reply 6 of 11, by elianda
This archive: ftp://retronn.de/dos/driver/cdrom.rar contains also the Teac driver disks for the e.g. 8x drive. It is most likely the same as for the 4x drive. It also features the CD-Player tool.
Youtube Channel
Reply 7 of 11, by retardware
Sadly I do not see the Toshiba driver in your link.
So I use my old Mitsumi driver, which never caused any problem for me, is multilingual, very configurable and lightweight (at least compared to Oakcdrom.sys) with only 11k resident.
As it is only driver, I hope it is OK to upload it...
Edit:
Just seeing the link from @elianda... WOW thanks!
The Teac driver only 3.7k... going to test this now.
My Mitsumi driver seems to be a bit newer than those of @elianda, so I'll leave the attachment...
    Mitsumi.zip
    178.48 KiB
    18 downloads
Reply 8 of 11, by BushLin
Did you notice the local copy, provided in the predicted event that the link to the manufacturer would eventually die?
https://www.legroom.net/files/howto/msdos/cdromdre.exe
The page, as originally linked is useful for the details on config.sys and autoexec.bat entries
Reply 9 of 11, by retardware
Ooops, no!
Great driver, nice options, and only 7536 bytes resident! 😀
Thank you, 27.5kB saved!
Reply 11 of 11, by Caluser2000
I've got a couple of cdrom install 3.5" disks laying about somewhere. Sing out if the above doesn't work out. Saves mucking around manully editing config.sys and autoexect.bat by hand.
