First post, by Hamby
I've installed win98SE on two different super socket 7 motherboards, using two different serial mice I know work, and 3 different serial cables... and win98SE will not detect my mice.... why might that be?
Reply 1 of 7, by FFXIhealer
Windows... or any other OS for that matter, does not "detect" ANYTHING on the Serial or Parallel ports. They have to be initialized with a driver for any device plugged into them to work. PS/2 ports are QUITE specific and limited to ONLY keyboard and mice, so it's very easy to have Windows do an initial check for those ports.
Reply 2 of 7, by bjwil1991
The serial mouse is a non-Plug and Play device and in order to get it detected, go to the Start Menu > Settings > Control Panel. Go to Add Hardware, press Next a few times and select Yes, detect hardware, next, and it should detect the mouse.
One more thing: run CuteMouse in the DOS prompt (press F8 and select Command Prompt Only) to see if the mouse gets detected from there.
Reply 3 of 7, by Jo22
Did you restart between each tries ?
Afaik, Windows 9x doesn't automagically detect these kind of device if the system is running.
However, it may probe for serial mice and serial modems during startup..
Reply 4 of 7, by retardware
Some of the answers above are not correct.
Windows 4 looks at the serial ports every time it starts.
If there is a MS compatible mouse installed, it is getting activated.
In case a mouse connected to serial port 1 or 2 is not being detected, there are only the following possibilities:
-Mouse is not MS compatible
-Port(s) have been deactivated (BIOS or Windows hardware profile)
-Usage of an improper extension cable
-Hardware fault
Reply 5 of 7, by The Serpent Rider
From my experience, Windows 98 SE has some problems with serial mouse identification after you change the motherboard.
Reply 6 of 7, by amadeus777999
