First post, by Sedrosken
- Member
Hi all,
I have the Adaptec AHA-2940U2 OEM card in my Pentium Pro machine and I have a need for the unofficial v3.10 BIOS for it. The file name is 2940u2w_bios_3100.exe, and I can't find it anywhere, though I did see a hint somewhere that it may have found its way over here at one point back when this was still on a zetafleet domain. I know it says 2940u2w, but I have also read that the 3.10 BIOS has been tested and confirmed working with the 2940U2 OEM despite what Adaptec themselves have to say. I also tried the V2.57.2 BIOS that is still available on MicroSemi's page for it, but that actually does not support the 2940U2 OEM -- it'll flash and detect the drives and even boot from them, but I can't get into the SCSISelect! utility.
Edit: The bare ROM file itself would also work, as I have the flashing utility already: 4u2w3100.rom
Shoushi: Dimension 9200, QX6700, 8GB D2-800CL5, K2200, SB0730, 1TB SSD, XP/7
Kara: K7S5A Pro, NX1750, 512MB DDR-286CL2, Ti4200, AU8830, 64GB SD2IDE, 98SE (Kex)
Cragstone: Alaris Cougar, 486BL2-66, 16MB, GD5428, CT2800, 16GB SD2IDE, 95CNOIE
