First post, by EleDip
Greetings! I'm seeking some advice for getting a HDD working with an old system I am trying to refurbish, though I guess I can use this topic for any follow-on questions about the system.
For now I am just trying to install MS-DOS 6.22 on this system, but having HDD related problems.
Here are some pics of the i430VX SOCKET-7 mainboard, which I have identified, I think correctly, as a PC Chips M520 (http://cwcyrix.duckdns.org/techpage/html/m9.html). Follow that link for manuals, specs, etc.
One example HDD I am trying to use is a WD CAVIAR AC22100H.
Another example HDD I am trying is a FIREBALL EL5 1A
These drives are working well and have been zeroed/tested on a newer Linux system.
To illustrate the issue I am having, I'll go through my procedure of trying to get a drive running on the SOCKET7 system.
* Drive Jumpers are set to MASTER or SINGLE (when available)
* the HDD is the only IDE device connected (trying only one drive at a time).
* The HDD is connected to the end of the 40-wire IDE cable.
Now here's the first sign of trouble: With the BIOS's HDD detection set to AUTO, the drive is recognised but the name garbled primarily with with "$" signs in the name..
* The WD CAVIAR AC22100H appears as "WDC$AC22100H" (on a newer PC the drive shows as "WDC AC22100H").
* The FIREBALL appears as "QUANTUM$FMREBALL EL5.5A$ $ $ $" (on a newer PC the drive shows as "QUANTUM FIREBALL EL5.5A"). Sometimes the text is garbled slightly differently, but usually it's the same.
Any idea what that garbled text indicates?
But despite the glitched name, the system posts and boots the MS-DOS 6.22 install floppy with the HDD assigned to Primary. Master as "LBA, Mode 5, 2112MB" (in the case of the AC22100H):
But then MS-DOS installer gives the error "Setup cannot install MS-DOS 6.22 on your computer. An error was detected while trying to read or write to your hard disk":
Ok, so then I try running the IDE HDD AUTO DETECTION in BIOS:
And note that option 1 (NORMAL) has the same CHS settings that are marked on the HDD's sticker, not option 2 (LBA - which was the default), so I try option 1:
And during boot it now shows the Primary. Master as "CHS, Mode 5, 2112MB" (in the case of the AC22100H):
But I get the same error with the MS-DOS installer: "Setup cannot install MS-DOS 6.22 on your computer. An error was detected while trying to read or write to your hard disk" 🙁
Booting to DOS floppy and running FDISK gives me "error reading fixed disk".
Things I have tried to overcome this issue:
* Several different hard drives.
* Several of the later BIOS (from link above), as well as the BIOS the board came to me with.
* Different IDE cables, to rule out issue with cable.
* Using the motherboard's secondary IDE slot, to rule out issue with just primary slot.
* Different jumper settings for the HDD including SINGLE/MASTER/SLAVE
* The "alternative jumper settings" for the AC22100H as described at https://stason.org/TULARC/pc/hard-drives-hdd/ … ATA-ENHANC.html
* Removed CMOS battery, disconnect power for a few minutes, replace battery.
* Load BIOS defaults.
* Formatting the HDD and installing MS-DOS 6.22 onto it using a different PC. So I knew I had a working DOS install on the drive (but then the i430VX system wouldn't boot from or properly recognise it).
2 days into this I am thinking that perhaps the issue lies with bad caps or chips on the motherboard, though I can't see any damage. 😐
Are there any pro tips from the hyperspace bypass on how to fix/diagnose this HDD detection issue further?
Reply 1 of 15, by Kiteless
You have tried about everything I would have. Bad caps are a possibility even though they are not showing any physical issues. But I think that's unlikely. It may seem odd but have you tried going down to say, a single stick of RAM? Also I'm guessing you would have tried this if you had one, but can you try and use a PCI or ISA IDE controller?
And to confirm, these drives work totally fine in another system (that you formatted them in)? If so, does the garbled model number show up on the other system? Did you try the other IDE cabled in the other working system?
That's a nice KLEEEEN AT mobo. I hope you can get it working.
YouTube channel
https://www.youtube.com/channel/UCTfnRX4AWhbYJuguUcEff-g
Main Systems
NuXT
IBM 5140
486 DX4 100Mhz (Mainly DOS)
AMD K6-2 500Mhz (Mainly DOS)
AMD Athlon 700Mhz 9700 Pro (Win 98)
Pentium D 3Ghz 4670 AGP 8x (Win XP)
Reply 3 of 15, by gdjacobs
Double check everything. I once had hard disk misbehavior with CPU VID configured incorrectly.
Reply 5 of 15, by EleDip
First of all I should say that the problem seems solved 😀 So read backwards if you just want the solution that seems to have worked for me.
I had run memtest86+ from floppy and the RAM passed the tests but due to your suggestion I tried removing all except 1 RAM stick, but found (I think) that the mimumum sumber of SIMM sticks this board will post with is 2 sticks (same SIMM "Bank"). This seems to be confirmed in the manual, and I'd love to know if this 2-stick minimum is a general rule with all motherboards that use SIMM memory?
Actually, maybe it's worth mentioning this system came to me with a PCI SCSI ultrawide controller installed along with a SCSI CDR burner and 2x SCSI HDD's that sound like jet planes, and it was booting from SCSI before I removed the SCSI adapter from the system. In light of the problems I am having with the onboard IDE perhaps the SCSI controller is a clue that the original owner back in ~1996 was also having trouble with the onboard IDE. However, even if that's the case I would like to get as deep as possible into the cause and fix the board to work with the onboard IDE if possible. I plan to repurpose the SCSI controller but I do have a PCI IDE controller on its way in case I can't get the onboard IDE working reliably by the time it arrives. I'm pretty sure that a PCI/ISA IDE controller would bypass the problem - thanks for this suggestion!
Yes the drives work totally fine in multiple other systems, and without the glitched model number.
quicknick wrote:
Try with internal/external caches disabled, see if anything changes.
Thanks for the suggestion, I'll definately use it in future!
This suggestion made me check that the jumpers were all set correctly on the board. As a conequence, I changed a few things that I think were set incorrectly according to http://www.elhvb.com/webhq/models/pcchips/m520.htm
Wolfus wrote:
Try whatide, if it will show same c/h/s numbers as on the sticker.
Looks very useful. I found WHATIDE hard to track down but found it at https://jigo.lu/index.php/ms-dos/dos-download … s-and-programs/
Progress was made, thanks to this suggestion. I took the IDE cable from my other computer that is working with the drives in question, and moved the known working cable to the i430VX system and woot! the drive (WD CAVIAR) booted properly on the machine for the first time ever, booting to DOS that had been installed to it using another computer. However... the machine soon locked up refusing to read from the drive, then refused to recognise the drive again on subsequent reboots.. at best showing the garbled model number (if anything) and acting just as it had with the original cables. So it was like physically playing around with the cables would help, which seems to me a pretty strong sign that there's something physically wrong with the IDE part of the connections, perhaps some of the solder connections or PCB traces to the 'southbridge' equivalent...
I breadboarded the motherboard to examine it more closely with a multimeter and a USB microscope to look for any sign of broken traces and found that the board was much more dirty that it appeared. This pic is of the pins of the SB82371SB chip that the IDE sockets are connected to. I'm amazed how filthy the board was considering it looks pretty clean and neat to the naked eye (i.e. first photo in thread).
I didn't find any specific damage except for the dirt so I dusted off the board using a small anti-static brush and blasted it with canned compressed air, which made a massive difference. Here's a pic of the same area after a little cleaning:
And now I'm happy to say that the hard drive model numbers appear nornally during post and boot successfully every time. I never found the specific thing that was causing the drives to glitch but belive the issue was caused this debris on the motherboard, some of which muct have been somewhat conductive. Fingers crossed that the problem won't resurface but I think it's fixed now. Anyway it's a real lesson to me to clean old electronics carefully before considering them broken. A bit of a weird solution but I think it's worked! (And if the problem re-surfaces I will come back and let you know my success was short lived).
Anyway I'm very glad I asked for help as your ideas helped encourage me to try things out just when I had thought to give up. Thanks everyone!
ps: During my search for answers I happened across this "IDE & LPT DB25 port Tester test card" on eBay, and I had considered getting one to test the IDE sockets on the motherboard:
Reply 6 of 15, by EleDip
doh! While I have a much cleaner board 😀 it seems my success was short lived. Bet you could have seen that coming 😵
Since my last post I've been trying to get both CDROM and HDD to play nice together on this system, during which I would have rebooted ~100 times with out any sign whatsoever of the glitched HDD model numbers during startup... I was able to boot reliably to CDROM or HDD but only if there was only one attached to the system: trying many many possible combination of jumpers, Primary/Secondary MASTER/SLAVE setups etc with multiple different drives and multiple CD drives and multiple cables, etc. And now.. the glitched names have returned and I can only boot to floppy, so I'm back to square one. 😲
I have noticed that the BIOS is being modified during post (after booting once it's reading back a different image on the tl866 than was written to it), and I'm not sure that's normal? I'll start another topic about that and will post here again if I make any progress with the glitched model number issue, then any further issues with the system.
Reply 7 of 15, by Tiido
ESCD is often written into the BIOS chip.
Have you tried to lower the FSB to see if it would make a difference ? Jump from 66 to 60MHz or perhaps 55 can show some improvement and perhaps disabling of cache also. If those have no effect the problem is not related to some timing violation but instead something physical (bad via, connector etc.)
Reply 8 of 15, by EleDip
knowing whether this is ESCD is a bit over my head. I've attached the original BIOS file along with the version I get after 1 boot. I've also attached a pic of a hexdiff of the main area of difference. If you know what to look for, please tell me if that looks like ESCD data to you?
I will try lowering the FSB and report back if there is any difference. Thanks for your suggestions!
(for future reference, the BIOS I am currenly using is the one from the file 520_Bios_19981207S_UNI [NP].zip downloaded from http://cwcyrix.duckdns.org/techpage/download/ … 525-stuff/bios/)
    316.45 KiB
    108.64 KiB
    9 downloads
    original bios
    changed-BIOS.zip
    92.58 KiB
    11 downloads
    changed bios
Reply 10 of 15, by EleDip
Hi again. First thank you for all the suggestions which were very helpful!
I'm glad to report that the problem is fixed for real this time 😁
Yesterday the board was giving very clear indicators that it was suffering from an intermittant physical issue (as if to remind me that it was already obvious):
The CDROM was jumpered and set to pri. Master. The HDD was jumpered to 'single' and set to sec. Master. I went into BIOS and chose "LOAD BIOS DEFAULTS" and then set CDROM to be the first boot device, that's all I changed. The model names enumerated without glitch during POST and I had it sucessfully boot from CDROM with full access to both HDD and CD (HDD which had been formatted in another computer). For the first time, both IDE devices were working!
On the very next boot, and without touching anything except the keyboard (Ctrl-Alt-Del) the HDD enumerated with the glitched version of the name, and the CDROM gave a "Boot from ATAPI CD-ROM : Failure ..." message, which I had been receiving many times over the last few days. Incidentally, the CDROM spun up normally when it attempted to boot from it.
Next boot, with my fingers pressing gently down on the SB82371SB chip, neither drive enumerated at all during POST. And next boot, pressing gently on the secondary IDE connector, both drives enumerated but both had glitched names.
So, I was pretty certain it was something physical with the board. I had ordered one of the IDE testers mentioned above but that was weeks away, so I set about tracing all the IDE connections on the pcb...
I used an IDE pinout diagram (https://pinouts.ru/HD/AtaInternal_pinout.shtml) along with the datasheet for the PCIset SB82371SB chip (http://pdf.datasheetcatalog.com/datasheet_pdf … d_SB82371SB.pdf) to find out which pins the IDE socket was supposed to connect to.
What I found was thhat IDE pin 13 did not have a good connection to the chip and went through a funny looking via.
148 KiB
Sure enough that via was the culprit and after I bypassed it with a jumper the board worked as it should.
77.26 KiB
I then bypassed it permanently by soldering a bodge wire on the underside of the board that would effect the missing connection. I did try to fix the via but it was too small to fix without damaging the board.
427.65 KiB
I would guess that this board's IDE had been giving problems since leaving the fabricator and that is why the prior owners had used a SCSI controller for the drives. I had read somewhere that PCCHIPS boards are of "sub-par" quality, and perhaps this defect is further evidence of it!
I am very glad to have this system fixed. The added benefit of sticking with it is that during the process of diagnosing the system for way too long I have become strangely attracted to it -- something like stockholm syndrome 😀
452.76 KiB
Reply 11 of 15, by Tiido
Congrats ~
Reply 12 of 15, by Kiteless
EleDip wrote:
Hi again. First thank you for all the suggestions which were very helpful! […]
Dude this is an awesome fix! Great work. I'm pretty sure I would not have figured that out. Glad to see this Socket 7 mobo get rescued even if it is a PC-CHIPS. Haha.
YouTube channel
Main Systems
NuXT
IBM 5140
Reply 13 of 15, by EleDip
haha, and thanks! Unfortunately the fix is more a testament to the unsavoury amount of time I spent trying to debug the issue than anything else 😀 I spent way too much time believing that the board was probably working and that I was just doing something wrong with the BIOS and/or IDE jumpers/cables... as this is the first retro PC I've worked on... but it was a good experience and may help me diagnose similar issues faster in future.
I'll really be interested to see if the IDE tester I ordered would have helped me find the issue sooner, and plan to try disconnecting my fix and report back here about whether the IDE tester shows anything helpful if/when it arrives.
ps @Kiteless: Looking forward to more videos in your c:\90s_tech youtube channel -- great work!
Reply 14 of 15, by Kiteless
I'll be keeping an eye out here for your findings should you do that. A lot of time sure but I think it was worth it.
And thanks for the positive vibes on the new YouTube channel. I just uploaded my part 2 of the 486 build. It was a long video with LOTS of cuts to keep pacing fast and still ended up being nearly 40 minutes long. Cheers!
YouTube channel
Main Systems
NuXT
IBM 5140
Reply 15 of 15, by EleDip
Just a quick follow-up on the IDE slot tester which arrived last week.
I disconnected the wire I had soldered to return the fault to the motherboard and sure enough the tester shows that there is a bad connection on PIN 13.
274.71 KiB
tester showing bad pin
So it Looks like the tester would have helped to diagnose the issue much faster. Though the tester was in no way required it's reassuring it would have worked!
The Chinese written on the tester was a little difficult to interpret so I recorded the IDE tester's pinout in this pic.
1.22 MiB
ide tester pinout
Really enjoying those videos 😎
