First post, by MokahTGS
MokahTGS
Offline
Description of problem: Installation runs fine, but when trying to run CRUSADER.EXE I get the following error output: Unable to open file (null), in file FILE\FASTFLEX.C, line 38.
I've searched these forums and found suggestions but nothing seems to work. The CD drive is mounted right, the memory settings are as they should be.
Can anyone help me with this?
Mokah
The Grumpy Strumpet
