Reply 280 of 440, by Nexxen
Hola señores!
I've used the win9x (ver 1.01.0 - nvember 2019) on win98se (fresh install) version with a Cyrix MediaGx 200GP and it reports the FSB changing from ≃20 to 33.44 mhz and all odd figures in between (19.84, 22.22, 24.24 ...).
Frequency varies accoridng to the multiplier which stays at 6x (correct).
Motherboard is a ST-Mgxm with Cx5520 chipset.
    M2M9Y4.txt
    12.41 KiB
    62 downloads
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 281 of 440, by CHiLL72
CHiLL72 wrote on 2020-05-09, 17:08:
CuPid wrote on 2020-05-09, 16:24:
CHiLL72 wrote on 2020-05-08, 20:05:
This latest version still has a bug that I noticed on the Win9x 1.01 version on your website: the first time I run it on Windows 98SE on my ASUS CUBX-E Pentium III system, it shows Vcore on the first tab. If I close and then start CPU-Z again, Vcore is not displayed anymore.
This is not good sign. Could you please save a TXT report the 1st time and another one the second time and post them ?
I guess cpuz does not show vcore again until a reboot ?
Yes, that is correct, only after a reboot Vcore is shown again. I will save and post the report later.
Strangely enough, I cannot reproduce the problem with the latest version anymore... It did happen with version 1.01, but after closing that, running version 1.03 again, closing that and starting 1.01, Vcore did appear... Go figure.
I did save the reports however. 2nd run of version 1.01 did not show Vcore.
BTW, the only change I made to the computer in the meantime was change the battery, as the CMOS clock would not run when the system was turned off, so time and date were off.
Waveblaster MIDI boards: https://waveblaster.nl - online now!
Reply 282 of 440, by CuPid
CHiLL72 wrote on 2020-05-10, 10:35:
Thanks for the test.
As I suspected the version 1.01 locked the smbus and therefore the 2nd run showed no SPD and no sensor data. That was indeed fixed in the meantime.
Edit : I did not pay attention to your CPU, nice (and rare) model !
I need a vacation.
Reply 283 of 440, by CuPid
Nexxen wrote on 2020-05-09, 22:46:
Hola señores! […]
Hola señores!
Hola ! and thanks for your report.
This is indeed very strange. I have a look and let you know.
I need a vacation.
Reply 284 of 440, by red-ray
CuPid wrote on 2020-05-10, 19:01:
I suspect it's not an SMBus lockup and the issue could well be that CPUZ either does not have code to drive the SMBus Multiplexor or the code is incorrect. Note how the SPD is on SMBus #1 and I don't think there is SPD data in any of the CPUZ save files.
[SMB Bus] <- SIV32L - System Information Viewer V5.48 Beta-08 ASUS-CUBX-E::Chiel
# Device Name |Bus-Numb-Fun| Port Multiplexing RM GB SO CO Vendor-Dev-Sub_OEM-Rev [Y]INUSE Wait 0 of 801 ms ASUS CUBX-E
0 ASUS CUBX SMB [ 0 - 04 - 3 ] E800 [Y][_]#0 BF 8086-7113-00000000-02 Intel 82371EB PIIX4E Power Management Controller
1 ASUS CUBX MUX [ 0 - 04 - 0 ] E437 [Y][_]#1 18 67 00 8086-7110-00000000-02 Intel 82371EB PIIX4E ISA Bridge
Slave SMBus Device Host Peak Data Hex Data
Device Description Status Time Size Offset 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
|0_10| 04 59 0000
[0_2D] AS99127 (ASUS) 02 221 0010 00 B6 B7 5D 5E B6 CB 05 CD A7 F8 A5 AC 8C 68 54 F8
0003 40 2D 20 5C
0004 50 31 8F 48 E2
0003 70 00 81 05
[0_2F] 02 221 0010 00 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __
[0_48] 08 214 0001 00 __
[0_49] 08 277 0009 00 27 .. 5C 64 27 .. 5C 64 26
|0_4A| 04 113 0000
|0_69| <excluded> 00 0 0000
|0_7F| 04 62 0000
|1_10| 04 61 0000
[1_30] 02 221 0010 00 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __
[1_31] 02 221 0010 00 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __
[1_50] DIMM SPD Data 02 221 0010 00 80 08 04 0C 0A 02 40 .. 01 75 54 .. 80 08 .. 01
[1_51] DIMM SPD Data 02 221 0010 00 80 08 04 0C 0A 02 40 .. 01 75 54 .. 80 08 .. 01
[1_60] 02 221 0010 00 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __
[1_61] 02 221 0010 00 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __
[1_62] 02 221 0010 00 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __
[1_63] 02 222 0010 00 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __
|1_7F| 04 63 0000
Total of 2 SMBuses and 12 SMBus Devices in 13.264 seconds (0.757 KBps). Slaves Probed 223. [Scan Range]0_10 to 1_80. [.. -> 00 : __ -> FF]
[ OK ] [ Copy] [Windows] [Machine] [ DIMMs] [Sensors] [USB Bus] [ SPD ] [PMB Bus] [Volumes] [SMB Bus] [PCI Bus] [ALL Dev]
Reply 285 of 440, by ATauenis
CuPid wrote on 2020-04-17, 11:36:
feipoa wrote on 2020-04-17, 10:44:
Is CPU-Z able to display the graphic card information for VLB cards? Everything in the Graphics tab is greyed out.
No, I don't have the smallest idea about how to detect VLB or ISA cards.
Probably they can be detected by reading VideoBIOS. Most of cards displaying their name on startup time, and the name is hardcoded into ROM. So to get the card name a finding of the hardcoded string in the VideoBIOS dump should be enough. However, detecting of VRAM type, clocks, etc seems to be vendor-specific. Or driver-specific. Some drivers are displaying information in system Control Panel, so probably there an standardized API is exists.
15.8 KiB
OAK OTI 077 also showed VRAM size for me (on 386 and Microsoft's driver from Win95 CD).
But other drivers does not doing such. Some info like GPU type and amount of VRAM can be retrieved through VESA calls. But this needs an DOS program (like SciTech Display Doctor) or an VxD driver.
2×Soviet ZX-Speccy, 1×MacIIsi, 1×086, 1×286, 2×386DX, 1×386SX, 2×486, 1×P54C, 7×P55C, 6×Slot1, 4×S370, 1×SlotA, 2×S462, ∞×Modern.
Reply 286 of 440, by Carlos S. M.
i got CPU-Z scores for Pentium Pro 200 (66x3) and 233 (overclock, 66x3.5), results were from a Windows NT enviorment (Windows 2000 Pro). Will post screenshots later (got them, but is in another computer and only have the scores anotated right now)
Pentium Pro 200:
CPU - 322,2
FPU - 1289,7
Pentium Pro 233 OC:
CPU - 376,4
FPU - 1504,2
System specs:
Pentium Pro 200-233
128 MB EDO
Intel VS440FX
Geforce FX 5500 PCI
20 GB HDD
Windows 2000 SP4
Reply 287 of 440, by TechieDude
I tried it and now it displays L1 Cache properly. It doesn't show the lithography of the CPU, though.
Also, would it be possible to show what kind of board cache is installed on the board (Asynch, Pipeline Burst etc.)?
Oh, and sorry for taking so long.
    USER.txt
    19.61 KiB
    56 downloads
Reply 288 of 440, by CuPid
red-ray wrote on 2020-05-12, 10:30:
hi Ray. There is a mux indeed, but the problem was not related to the mux because the LPCIO only appeared at the 1st run with the previous version, and all subsequent smbus calls failed.
> ATauenis : I'm currently working on that, at least on the most popular video card models.
> Carlos S.M. : thanks for the scores, I add them in my list.
> TechieDude : thanks. Yes I think it is possible to read back this information, at least on the 430TX.
I need a vacation.
Reply 290 of 440, by Daniël Oosterhuis
One weird thing I've run into with an Epox EP-58MVP3C-M board is that CPU-Z can't tell the multiplier setting and FSB for either my K6-3D, or my Pentiums. Yet, those values when using a Cyrix 6x86 PR166+ get detected completely. That said, I've found this board has some weird behaviors with most CPUs when it comes to the jumper settings. On a lot of them, setting the jumper settings per the silkscreen results in frequencies that would not be correct at those settings, and it just so happens that with the Cyrix, it behaves as I would expect it. That might be a bug with my board, or its BIOS, so I'm not necessarily convinced this is a problem with CPU-Z VE.
It has however let me to notice that Vintage Edition validations without the FSB and multiplier still get marked as "Validated" on the valid.x86.fr site, but internally seem to still be classed as rejected. Namely, I shared the results to someone in a Slack chat, where the preview still said "Rejected dump" for all validations other than the Cyrix. Also, my Pentium MMX 233 running at 301MHz should have been in the top 15 if it was actually validated, which it however is not, thus it doesn't show up there. Is this intentional? I understand if the Vintage Edition demands for validation are more lax due to the fact that multiplier and FSB settings on older boards can't always be read, but in that case, there should be a separate validation classification for vintage CPUs to avoid confusion.
Validations in question:
Pentium MMX 233 @ 301MHz | Pentium 120 | AMD K6-3D 266 | SGS-Thompson Cyrix PR166+
Reply 291 of 440, by CuPid
Daniël Oosterhuis wrote on 2020-05-17, 10:12:
One weird thing I've run into with an Epox EP-58MVP3C-M board is that CPU-Z can't tell the multiplier setting and FSB for either my K6-3D.
Those two models have no register to read the multiplier, and it is not possible to guess without ambiguity (a Pentium @ 100 MHz for example can be 1.5 x 66 or a 2x50). On the contrary the Cyrix reports its current multiplier.
Yes it seems to be a bug on the validation side, the classic version does not allow an empty BCLK, but the VE does, in theory. It needs a check anyway.
I need a vacation.
Reply 292 of 440, by feipoa
Attached is the report for an IBM 486BL3 running at 75 MHz. Although L1 is enabled, the benchmark result is abnormally low so I'm going to play around with CPU register settings.
CPU-Z is incorrectly reporting the Package as Socket 168 PGA. The IBM BL3 is QFP only, but it is currently on an adapter that interfaces to the motherboard's PGA-132.
CPU-Z is incorrectly reporting the core speed. It is running at 75 MHz not 66.09 MHz.
CPU-Z is incorrectly reporting the L1 cache size. The BL3 has 16 KB, not 8 KB.
    Bl3-75.txt
    2.59 KiB
    53 downloads
Reply 293 of 440, by feipoa
I cannot figure out why the CPU-Z benchmark results are abnormally low. What is further surprising is that when I disable L1 cache, the benchmark results increase, e.g. from 11.0 to 12.6 ALU and from 42.1 to 35.5 FPU. The cache is definitely enabled in DOS because cachechk shows a step at the 16 KB boundary and the DOOM result is substantially better with L1 on.
EDIT: I have resolved this issue. The IBM BL3 can only cache up to 16 MB of RAM and I had 32 MB installed. Removing 16 MB of RAM put the benchmarks numbers back into the expected range. CPU = 43.5 and FPU = 55.8 for IBM 486BL3-75.
Reply 294 of 440, by CuPid
Thanks feipoa.
The BL3-75 should indeed score around 40 in the ALU test.
The problem could be related to the reference timer used in the bench, you can check if timers are OK with the "Tools" -> "Timers" feature, and start a counting and see what is happening.
The detection of the BL3 is a real struggle under windows, because it relies on the support of MSRs registers and an exception handling mechanism at the kernel level that is not supported by win9x.
I've made two versions for you :
- that one does force the MSR reading, and then should report the BL3. On anything else than a BL3, it will generate a blue screen. But at least it will allow to check if the routines are correct, and maybe the bench result will benefit of the correct clock speed : http://download.cpuid.com/betas/cpuz_w9x_bl3.zip
- that one is a normal version with logging. Please unzip it and run it. It will create a "logs" folder at the same level as the exe, can you please send me back its content ? http://download.cpuid.com/betas/cpuz_w9x_dbg.zip
I need a vacation.
Reply 295 of 440, by feipoa
I'll run these tomorrow. I've been staying up too late and its showing in my health.
You have attached two different version of CPU-Z. You want me to run both and send the logs?
Issue with CPU-Z bench score has been resolved. I edited my post, but I think you missed it. The biggest drawback of the IBM 486BL3 is the inability to cache more than 16 MB.
Reply 296 of 440, by CuPid
feipoa wrote on 2020-05-20, 10:01:
Only the dbg version will generate a log file. For the other version, if everything is OK no need to save anything.
BTW, the versions include a video BIOS dump feature (in Tools), a report would be useful for the ISA/VLB video cards detection.
Thanks !
OK, the score is in the expected range.
I need a vacation.
Reply 297 of 440, by feipoa
I've attached the report and Video BIOS dump for the special _bl3 version of CPU-Z. It seems to report correctly now, but isn't very useful unless you can integrate it into the normal version of CPU-Z.
I've also attached the debug file from the log folder. That version still shows the incorrect CPU.
    IBM486BL3_debug.rar
    584 Bytes
    53 downloads
    IBM486BL3_report.rar
    41.53 KiB
    52 downloads
Reply 298 of 440, by CuPid
Thanks feipoa.
As you pointed this is not very useful, unless I find a way to read the MSR without harm.
My idea is to run the MSR read instruction at the user level (and not at the kernel level) and read back the exception.
If the CPU does not support the MSR read instruction, it should report STATUS_ILLEGAL_INSTRUCTION. If it does, like the IBM 486, I expect to get STATUS_PRIVILEGED_INSTRUCTION, meaning that the instruction is supported, but can"t run in user mode. At that point I can run the instruction at the kernel level w/o risk because I know it is supported.
But in your report, the error code is STATUS_ACCESS_VIOLATION.
I need a vacation.
Reply 299 of 440, by feipoa
Oh no. Is there any instruction you can send to the CPU that only an IBM 486BL3 will return a unique response?
