First post, by nztdm
Hello
Same ol same ol.. help me identify a 386 mobo with no branding.
I'll trawl through TH99 images later, but just checking if anyone knows.
FYI: It's a board I may purchase. I wanted a suped up 386. I see a desirable chipset. It has 33MHz CPU installed, but I only see a 50MHz oscillator, which I assume means it's running at 25MHz.
I see 64K of 25ns cache (8 x 8Kx8). I can get 32Kx8 12ns equivalents from mouser (will need to find the 22-pin TAG ones elsewhere).
Hopefully the chipset isn't binned for only 25MHz, and is unstable if I install an 80MHz oscillator.
Cheers
JD
