Are there 8-bit isa scsi cards?
First post, by precaud
It's true; memory (the human kind) becomes less reliable with age. I seem to remember having an 8-bit ISA SCSI card back in the day. I still have the Corel SCSI driver disks for it.
Am I dreaming? Or did such a thing exist?
Reply 5 of 21, by PC Hoarder Patrol
Couldn't say - never tested it beyond checking it enumerated at POST. If you're interested I can check it out - I have some 50-pin DEC, Compaq, Quantum & Seagate drives I could try.
Reply 6 of 21, by precaud
Thanks for the offer but no need to do that, I was just curious.
The context for this is: I found three Teac SD-340 SCSI drives in a box last night. Made me think again about maybe keeping the XT clone MB I have and making a working system with it. Problem is, I don't have any 8-bit hard drive controllers of any type here. I got MFM and SCSI drives from the day, but no 8-bit ISA controllers. I'm pretty sure I used to have them, but maybe not. I only dipped a toe into the 8-bit PC/XT world briefly; it did not present a compelling improvement over what my CP/M-80 machines did.
Reply 9 of 21, by precaud
So I've been loooking around since my last post, and indeed, bootable 8-bit ISA SCSI cards are as rare as hen's teeth, and priced to match when available. Is this a case of small numbers of them to begin with? Many of them still being used? Collectors cornering the market?
Reply 13 of 21, by Anonymous Coward
There's more to a good SCSI controller than just having external headers. A lot of those cards were just designed to be used with scanners.
You want one with a BIOS that allows you to boot. It should support large drives, and it should have decent drivers that let you run stuff like CD-ROM drives.
I have yet to see an 8-bit SCSI controller better than TMC 850 with v8.x BIOS, though there are others that come close.
Reply 14 of 21, by dr.zeissler
I think I have a bootable 8Bit SCSI-Controller...but I think I did not have made fotos of it
https://www.flickr.com/photos/94839221@N05/al … 157657710688635
hm 🙁
Retro-Gamer 😀PowerMac 6100-66/Houdini 486/66 - G4 Cube 450/Rage128pro OS9.0.1 - Macintosh LC/Apple IIe Card OS6.0.8 - Acorn A4000 Archimedes - Unisys CWD 486/66 + Aztech Washington
Reply 15 of 21, by precaud
hm 🙁
My question is answered - its the collectors hoarding 😀
AC is right - all those cheapo cards on eBay have no BIOS chip, no internal header, and are for scanners.
Reply 16 of 21, by Anonymous Coward
It used to be possible to get the TMC 850MEX cards for next to nothing, like five or ten bucks. Those are the stripped down models that don't have the socket for the BIOS, but you could solder the hardware on and save a lot of money. If you see one of those, go for it. Unfortunately, I think others have already figured it out.
I think some of the future domain 16-bit cards can also work in 8-bit slots, but I've never tried so you'll have to read up on it.
https://www.ebay.com/itm/SCSI-ISA-APPLE-SCHED … BMAAOSwi0FcYCGQ
Reply 17 of 21, by Predator99
Also have some 8-bit cards, but only 1 with a BIOS. Dont think its a problem, you should be able to put the BIOS on e.g. a network card to boot from it - if you find the correct image.
1.58 MiB
Reply 18 of 21, by Anonymous Coward
The card with BIOS is a Seagate ST-01. Those are okay if you want to use hard drives (BIOS v3.3.1 or later required to run non seagate drives), but they don't have ASPI drivers so CD-ROM is not going to happen.
You can try a SCSI BIOS on an NIC with those other cards. It's worth a shot, but seems like a pain in the arse. I *think* the TI chips on those cards might be the same ones used on the future domain cards (even though they have VLSI chips). I think there was some of cross licensing agreement to produce those SCSI ICs. The ones on the Seagate cards are special though. They ordered a batch with some registers reversed which makes them incompatible with the TMC 850 drivers.
Reply 19 of 21, by precaud
I do not have an 8-bit ISA NIC here, so that option is out.
I just discovered a possible roadblock to using an XT clone for this system, and may have to go to a 386. If that's the case, I won't need an 8-bit card. Am putting it on hold while I research the hardware/software requirements more thoroughly.
