First post, by vmr_
I cannot find any information online about this motherboard, maybe some of you encountered this motherboard? I am looking for jumpers settings and max supported memory, or any details you can share.
Chipset OPTi 82C596/597 (Cobra)
The attachment cpc-5200 mobo.JPG is no longer available
Retro builds & sandbox
IBM XT 5160 | 286 | 386 | 486 | S4 SI5PI AIO & S4 Batman + P60 SX828
S8 & PPro 200 | SS7 FW 5VGF & Asus P5A & AOpen AX59PRO K6-III+ 550MHz
Asus K7M Athlon 1Ghz GDF | Abit SH6 Pentium III 1GHz SL4KL...
Reply 2 of 7, by derSammler
JP2 and JP3 are most likely Clear CMOS and BIOS flashing en./dis.
Given that there only is a 33.00 MHz crystal, it seems CPU speed is locked to 66 MHz.
Reply 3 of 7, by vmr_
thx, CPU did not come with the motherboard, plan to use it for testing - but might need a 66MHz one if indeed locked to 66MHz
Reply 4 of 7, by vmr_
JP1 in top left corner I assume is linked to battery...
Reply 5 of 7, by Anonymous Coward
Hope you're ready for some craptastic Pentium performance. If you're lucky it might even support 64-bit memory! PCI is bridged to the VL-bus. Even though the board doesn't have the VLB slot soldered in, you still get to enjoy the benefits of sub-par PCI bandwidth.
BTW, I think at least in the early versions of P66 it required more than 5V. Something like 5.15V or more. You might want to make sure your board can actually drive a P66...a lot of boards back then weren't reliable at 66MHz.
Reply 6 of 7, by feipoa
Just ensure that your power supply is running 5V on the high. IIRC, the Batman's Revenge board mentions 5.27 V.
Reply 7 of 7, by crackintosh
Hi. Dear topic starter,
Did you manage to read the BIOS content? Can you post it there ?
It is INTEL P28F001BX-T
Best regards.
