First post, by Abandoned Witch
Abandoned Witch
Offline
Abandoned Witch here once again, and I'm having problem with running Sentient (for Windows 95) on Windows 7 x64, first, when inserted the Sentient CD it gives an error regarding the CD not inserted in the local drive. Should I put the files on the Sentient folder instead? Should I use compatibility mode? Let me know.
The Witch will never die!!! At least there is hope.
There's no one but you on my mind, searching for a perfect ending that we'll never find!
