First post, by Almoststew1990
I've just moved house and I am trying to sort out my "office". I have a lot less space now, and I'll need an ITX W98/DOS system.
So what are my options for W98 / DOS gaming? I currently have a VIA "Samuel" C3 or something soldered CPU, ITX format motherboard. It has a PCI slot so I can put in a sound card. W98 performance will be meh (particularly 3D graphics) but probably adequate for those early 3D titles that can't run on XP / 7 / 10.
Can anyone think of a better way of getting a SFF W98/DOS PC?
Reply 1 of 7, by xjas
If your VIA motherboard has onboard audio, there's a good chance it's the 82C686B southbridge which has really good built-in DOS support. Use the PCI slot for a video card instead & you'll have a decent little system.
Reply 2 of 7, by Almoststew1990
It doesn't, I checked (I probably posted about the board when I picked it up). I can always physically switch between Voodoo 3 2000 PCI in W98 and SBL (or whatever I get to replace it) in DOS...
Reply 3 of 7, by Half-Saint
You could get a slightly bigger case with a dual PCI riser. That way you could use both cards at the same time. Also, if you have PCMCIA on your board, you could use that for audio as well.
Reply 4 of 7, by wiretap
+1 for a VIA board. I went with the C7, and stuck a dual PCI riser on it for SLI Voodoo 2's. Alternatively, you could use a single PCI video (i.e. Voodoo 3 or Nvidia FX5500) card in combination with a PCI sound card (Aureal Vortex, Sound Blaster Live, etc).
My Github
Circuit Board Repair Manuals
Reply 7 of 7, by Half-Saint
This was my setup back in 2006. I still have the beige pizza box computer, just don't really use it anymore. The grey tower was an AMD socket A system, still ran well at the time but I sold it around 2010-2011 (memory is fuzzy).
259.77 KiB
277.44 KiB
