First post, by MAZter
Hello everybody!
I trying to use pcmcia in Toshiba Laptop in MS-Dos, but looks like some important files does not exist.
Is anyone can provide this file:
SSCB16TO.EXE
from "System Soft Card Soft 16" ?
Thanks!
Doom is what you want (c) MAZter
Reply 1 of 6, by Caluser2000
If you have no luck you may want to try IBM PC Dos 6 up as I understand it has very good pmcia support
Reply 4 of 6, by MAZter
lolo799 wrote:
What is your laptop model and what kind of PCMCIA card do you want to use on it?
Laptop is Toshiba 2805-S202, cardbus controller ToPIC95
I tried:
SONY Vaio PCGA-CD51 CD-Rom, flashing and moving, but mscdex and driver can't detect device
and
Roland SCP-55 sound card, works fine in Win98, but in Dos I hear beep, but cardinfo wrote Manufacturer: "Unavailable", not working
Reply 5 of 6, by darry
Cardwizard.zip
1.04 MiB
68 downloads
from http://downloadt.advantech.com/download/downl … File_Id=1-17FK7
includes the file your looking for in the SOCKET.Z file . If you run the installer it should uncompress the file for you .
If you really just need the file, here it is :
SSCB16TO.EXE
15.51 KiB
56 downloads
