First post, by Miphee
I bought a Hercules card that was sold as working OK.
I hooked it up with my monochrome monitor (Casper GM-1489/D) but I can't get it to work right.
Other Hercules adapters work right with the monitor. It doesn't matter if I change the motherboard, it's the same in every computer (XT, 286, 386).
Sometimes I see the BIOS memory counting but the nonsense characters remain. Is this incopmpatibility or malfunciton?
It was sold as a Hercules card but I can't find any info on it. The jumper settings don't change much. Please help!
Reply 4 of 10, by Miphee
Okay, I made some progress. After your suggestion I checked around the RAM and found a burned capacitor and a broken trace. I fixed them and these are the results. Some of the characters are missing and appear in the wrong places. Where should I look next? I also included a correct image with a working card.
    1.79 MiB
    1.88 MiB
    1.76 MiB
    579.23 KiB
    With working card
    1.18 MiB
    Faulty card
Reply 5 of 10, by liqmat
I'm not digging that second shorter trace next to it. Can't tell the true nature of the damage from the fuzzy photo.
884.6 KiB
Reply 7 of 10, by Miphee
A few more pictures.
    1.81 MiB
    1.83 MiB
    1.84 MiB
Reply 8 of 10, by Miphee
Unfortunately I'm very stuck.
I measured what I could in-circuit. Either I missed something or one of the ICs are bad.
What does the one in the socket (UM2301) do? No datasheet or any info. My other suspect is the 74LS374 above the socketed one, it is connected via the broken trace to a memory chip. I tried in another motherboard, same missing characters.
Reply 9 of 10, by Anonymous Coward
According to the sticker in the bottom left corner of the card, it is manufactured by DTK. The PII-133 is likely the model number.
The closest match on TH99 is the PII-134
http://www.uncreativelabs.de/th99/v/C-D/50173.htm
Reply 10 of 10, by Miphee
Thank you all, I give up.
The font rom works fine on another card so it must be one of the logic ICs. I suck at soldering those so I won't risk further damage unless I know exactly which IC I'm supposed to replace. Too bad, it is a nice card.
