First post, by AlessandroB
https://drive.google.com/file/d/1sQKllcI4-GKn … iew?usp=sharing
https://drive.google.com/file/d/1V5U8hz_KNOSv … iew?usp=sharing
This SBC seems interesting... tell me about chipset, graphic and... your opinions.
The system now work at 160 Mhz without problem on Doom, CPU is not extremely hot (have heat sink and fan), bus can go 25,33,40, plus other combination to be discovered. Voltage 3,3 - 3,45 - 3,6,(look at the rear pics) but not find 5V.
Reply 2 of 2, by AlessandroB
And, for example, install a DX4_100 in this sbc, and install same cpu dx4_100 in this mainboard:
https://drive.google.com/file/d/1lodgEBAYQx1O … iew?usp=sharing
There is a huge performance difference?
There are some difference in graphic card (tseng vs trident), memory (30 vs 72 pin), chipset... these systems, are similar or very very different in a gaming performance?
