First post, by infernalgr
Hello friends
I'm the middle of building a retro pc and i stumbled upon some sound issues.
My system as of right now is a p3 866mhz on a esc p6-vaa motherboard with AGP PCI and ISA slots.
After some tinkering i got the ISA ES1868F to work under dos and windows 98, but there's a weird issue with the sound, everything sounds as if it's played at half speed and one octave lower, this is especially noticeable in wav files and game sound effects (not sure if it's happening with midi too cause i don't have something to compare it to right now).
It's the same deal under dos 6.22, and on win98. I've tried different IRQ and DMA settings under dos, different drivers under windows98, different isa slot, different bios version and i'm now out of ideas... Either the sound card it's self has a problem or I'm missing something quite obvious.
What should i do? my budget is VERY limited so i can't just go and buy a awe64 isa and be done with it.
Should i go the PCI route?
i'm open to suggestions.
Reply 2 of 16, by infernalgr
yea the rest of the system is running very well, i don't have another sound card atm unfortunately (nor another system to test the same sound card on) , I'm wondering if i can save the situation as is right now.
Reply 4 of 16, by infernalgr
kolderman wrote:
Can you try opl sound...like an early dos game select adlib. If it's ok then maybe a dma conflict is preventing normal playback of digital sound.
i'm not sure what opl was to do with playing wave files? and if it was a dma thing i would guess i wouldn't get sound at all... dunno
Reply 6 of 16, by infernalgr
Well here's what i see, there's a "NA" DMA on the isa device listing. No matter what i try in the bios i can't get it to register a DMA there, not sure if that's how it's supposed to be or that's a problem.
    974.19 KiB
Reply 8 of 16, by Tiido
It is probably a bad crystal that causes the problem of everything being lower pitched.
Reply 10 of 16, by Tiido
If there's none it most likely uses 14.31818MHz clock from the ISA slot and chances are it isn't at correct freq, the card is fine but motherboard is at fault instead.
Reply 11 of 16, by keropi
are you in GR infernalgr? most likely I have a 1868F card I can just send you - I am not using them anyways
Reply 13 of 16, by keropi
let me check tomorrow what I have at hand
I am located in Ioannina
Reply 15 of 16, by keropi
turns out the cards are Avance Logic ALS100+ ones... no idea about them tbh if you want one I can still send it over
