First post, by Nemo1985
Hello, since I have just 2 AT cases I want to get rid of my VX motherboards, they were useless back in time and imho they still are now.
First is a Full Yes 82430VX with coast module installed, without mmx support and fsb max 66mhz, 4 simm slots and 1 sdram slot
Second is a Lucky Star 5I-VX1F rev 2.1, 512kb cache, pentium mmx support, 75 and maybe 83 mhz support, 4 simm slots and 2 sdram slots.
Are they worth to be sold? How much?
Thanks.
Reply 2 of 7, by derSammler
MMX requires dual-voltage. It's worth nothing that you can go down to 2.8V if you are stuck with single-voltage.
Reply 3 of 7, by Deksor
Well they differenciate "VR voltage spec" from "Core voltage" and they even mention "P55C" in there : http://www.elhvb.com/mboards/fullyes/82430VX.html
So actually maybe they knew about the MMX' specs by the time they made their board but they couldn't test it ?
Reply 4 of 7, by Warlord
You can try to sell them, even if its not worth selling, its a better than creating e-waste.
Reply 5 of 7, by Nemo1985
Thank you for all the answers, I will try to sell them for a reasonable price, I think that after all the FY mb could be some more valuable thanks to the coast module?
Reply 6 of 7, by Anonymous Coward
I think they're worth keeping. Personally I'm tired of MMX. Real Pentiums didn't have MMX. The PMMX came out when Pentium was an EOL product, and that's not how it should be remembered.
Reply 7 of 7, by Nemo1985
I agree with you, unlucky I have just 1 pentium non mmx cpu (166-S)
In the meanwhile I completed the first system:
Lucky Star 5I-VX1F with Pentium MMX 200 mhz and 16mb simm memory.
I found some dispaired memory simm modules, can I ask your help to identify them? There is also a Dimm module rated as DDR but with notches compatible with sdram.
Here are the pictures: https://imgur.com/a/Se9rGnk
