First post, by Old PC Hunter
I was wondering if anybody here had benchmarks for quad Pentium 3 xeons or eight Pentium 3 xeons. I possibly want to build a system running four or eight of these processors because why not and see what it can do. The components seem cheap enough for me to buy, so I have decided i'll probably build one of these systems in the near future. If anyone has benchmarks for this kind of setup, it would be intriguing to see how they preform.
Set up retro boxes:
DOS:286 10 MHZ/ET4000AX1MB/270 MB HDD/4 MB RAM/Adlib/80287 XL
W98:P2 450/Radeon 7000 64 MB/23 GB HDD/SB 16 clone/384 MB RAM
XP:ATHLON X2 6000+/2 GB RAM/Radeon X1900XTX/2x120 GB SSD/1x160 GB and 1x250 GB 7.2k HDD's/ECS A740 GM-M/SB X-Fi
Reply 1 of 34, by Warlord
sounds like a fun project keep in mind they dont support sse2, sse3, or later instruction set extensions. only i say that so you understand in advance how far you can take a system like that. otherwise if you could run windows 10 and modern sh*t with 8 xeons.
Reply 3 of 34, by Warlord
yes but programs that are written to take advantage of multiple CPUs, dont all run on CPUs that dont support sse2 and later instruction sets. especially media applications, games and programs compiled with later versions of visual studio and other compilers. So just becasue you have 8 cpus doesn't mean newer software that might take advantage of 8 cpus will even run.
Reply 4 of 34, by The Serpent Rider
There's also very serious FSB limitation, which kinda ruins it all.
Reply 5 of 34, by spiroyster
The question is what SMP benchmarks are there, not can a quad P3 run modern windows?
Got to ask... what mobo? I pressume slot2 Xeons?
smallpt (OpenMP). In fact any program that supports OpenMP would probably scale nicely (given how OpenMP is used as an API). Might need to find real world results to compare against. There are some other SMP benchmarks, but I can't think of any atm, maybe also look at blender test scenes etc. Raytracing is embarrassingly parallel so scales well.
Reply 6 of 34, by H3nrik V!
You might find some interesting input here:
http://www.cpushack.com/2019/01/18/part-4-min … d-overclocking/
What CPUs were you considering? Tanners or Cascades?
Reply 7 of 34, by H3nrik V!
Well, there are 933's in 133 MHz FSB. Unfortunately only 256 kiB cache, though ..
Reply 8 of 34, by Old PC Hunter
I am probably considering 900 mhz Cascades. I know probably only 2 of my eight processors will ever be utilized at max, but it would still be awesome to have 4/8 in a system. Im planning on possibly using a Dell Poweredge motherboard from a 6400 or 8450, but if a better solution comes up i'll look into that too. For this system i'll probably dual boot an old operating system for if I want to play older games on it with an older graphics card, (I already have a 1999 system for the job but it would be cool to see how the Xeons function in older games) and I want to use a modern os as well to utilize the 4/8 processors and utilize modern applications to see how it holds up. I know there will be an SSE limitation but i'm not concerned as most of the stuff I want to run on the newer OS I can just run using a older version.
Set up retro boxes:
Reply 9 of 34, by H3nrik V!
I can fully understand that feeling 😎
Reply 10 of 34, by matze79
Yes if you use WIndows..
But there are other Options too.
Reply 11 of 34, by red-ray
Worse still they only support 2-way rather than 8-way systems.
I have a 2005 vintage SIV save file from an IBM 8681 with 8 x Intel Pentium III Xeon (Tanner), but that is from before I added a CPU benchmark. If you do get one I would like to know how well SIV runs on it. Using the save files in test mode I get:
Reply 12 of 34, by H3nrik V!
That's a shame .. Is that so for all Cascades processors, or only the 133 FSB parts?
Reply 13 of 34, by red-ray
Just the 133 MHz FSB ones, the 100 MHz FSB are good for 4-way and more in the right system.
I have a https://www.supermicro.com/products/motherboa … P3/HE/S2QR6.cfm, but never got around to getting it working
Reply 14 of 34, by Old PC Hunter
Thanks guys for all the helpful stuff. Does anyone here know of any other motherboards I could use for 4/8 Xeons besides the cheap dell ones? Such as ones that are any better?
Set up retro boxes:
Reply 15 of 34, by Old PC Hunter
Also, once I do eventually build the system, which i'll probably start piecing together in the next month or two, i'll make sure to hand over multiprocessing benchmarks for those who are curious.
Set up retro boxes:
Reply 16 of 34, by maxtherabbit
you are making my dual coppermine build feel very inadequate right now bro
Reply 17 of 34, by Old PC Hunter
Set up retro boxes:
Reply 18 of 34, by H3nrik V!
Looking forward to seing that. I am a total sucker for everything multi-socketed. 😎
Reply 19 of 34, by Old PC Hunter
Me too. Looking at classic multiprocessing is very enjoyable to me.
Set up retro boxes:
